QT5.3.2 support UI Chinese font's issure
haibohe
BSP is linux L3.14.28_1.0.0-ga   -〈yocto〉
QT5.3.2 support UI Chinese font. The default is English, and now need in QT UI to display Chinese characters, how to add fonts. Please help
#include "meihuantest.h"
#include <QApplication>
#include <QTextCodec>
#include <QTextEncoder>
#include <QtCore/qglobal.h>
#include <QDebug>
#include <iostream>
int main(int argc, char *argv[])
    QApplication a(argc, argv);
    QTextCodec::setCodecForLocale(QTextCodec::codecForName("UTF-8"));
    QFont font;
    font.setFamily(QString::fromUtf8("WeiQuanYi Zen Hei"));
    font.setPointSize(12);
    a.setFont(font);
    meihuantest w;
    w.show();
    return a.exec();
#include "ui_meihuantest.h"
#include <QDebug>
#include <iostream>
#include <QFontDatabase>
meihuantest::meihuantest(QWidget *parent) :
    QMainWindow(parent),
    ui(new Ui::meihuantest)
    QFont font;
    this->setFont(font);
    ui->setupUi(this);
    QFontDatabase database;
    foreach (const QString &family,database.families())
        qDebug()<<family;
        ui->textEdit->append(family);
        ui->label->setText(QObject::trUtf8("A祖国"));
        ui->lineEdit->setText(QString::fromLocal8Bit("B我爱你我的祖国"));
        ui->lineEdit->setText(QObject::trUtf8("C我爱你我的"));
        ui->lineEdit->setText(QString::fromLatin1("D中文"));
    resize(800,600);
meihuantest::~meihuantest()
    delete ui;
root@imx6qsabresd:/usr/lib/fonts# ls
DejaVuSans-Bold.ttf             c0582bt_.pfb            helvetica_180_50i.qpf
DejaVuSans-BoldOblique.ttf      c0583bt_.pfb            helvetica_180_75.qpf
DejaVuSans-Oblique.ttf          c0611bt_.pfb            helvetica_180_75i.qpf
DejaVuSans.ttf                  c0632bt_.pfb            helvetica_240_50.qpf
DejaVuSansMono-Bold.ttf         c0633bt_.pfb            helvetica_240_50i.qpf
DejaVuSansMono-BoldOblique.ttf  c0648bt_.pfb            helvetica_240_75.qpf
DejaVuSansMono-Oblique.ttf      c0649bt_.pfb            helvetica_240_75i.qpf
DejaVuSansMono.ttf              cour.pfa                helvetica_80_50.qpf
DejaVuSerif-Bold.ttf            courb.pfa               helvetica_80_50i.qpf
DejaVuSerif-BoldOblique.ttf     courbi.pfa              helvetica_80_75.qpf
DejaVuSerif-Oblique.ttf         couri.pfa               helvetica_80_75i.qpf
DejaVuSerif.ttf                 cursor.pfa              japanese_230_50.qpf
README                          dejavu_sans_11_50.qpf2  l047013t.pfa
UTBI____.pfa                    fixed_120_50.qpf        l047016t.pfa
UTB_____.pfa                    fixed_70_50.qpf         l047033t.pfa
UTI_____.pfa                    helvetica_100_50.qpf    l047036t.pfa
UTRG____.pfa                    helvetica_100_50i.qpf   l048013t.pfa
Vera.ttf                        helvetica_100_75.qpf    l048016t.pfa
VeraBI.ttf                      helvetica_100_75i.qpf   l048033t.pfa
VeraBd.ttf                      helvetica_120_50.qpf    l048036t.pfa
VeraIt.ttf                      helvetica_120_50i.qpf   l049013t.pfa
VeraMoBI.ttf                    helvetica_120_75.qpf    l049016t.pfa
VeraMoBd.ttf                    helvetica_120_75i.qpf   l049033t.pfa
VeraMoIt.ttf                    helvetica_140_50.qpf    l049036t.pfa
VeraMono.ttf                    helvetica_140_50i.qpf   micro_40_50.qpf
VeraSe.ttf                      helvetica_140_75.qpf    unifont_160_50.qpf
VeraSeBd.ttf                    helvetica_140_75i.qpf   wqy-microhei.ttc
c0419bt_.pfb                    helvetica_180_50.qpf   wqy-zenhei.ttc
WenQuanYi Zhe Hei
WenQuanYi Zhe Hei Mono
WenQuanYi Zhe Hei Sharp
WenQuanYi Micro Hei
WenQuanYi Micro Hei Mono
Please help
No display
Rita_Wang
Hi haibo,
Here you need to download the Chinese fonts first and put it into the directory /usr/lib/fonts on your board. Then set the font you need in the main.cpp of QT.
You also can set the font type you like. Take " SimSun" as an example:
QFont font;
font.setPixelSize(20);
font.setFamily("SimSun");
QApplication::setFont(font);
Hope this can help you.
Dan
Rita_Wang
Hi haibo,
QFont font;
Dan
