Stop Pop Up at startup
ronaldpatton
How do I prevent this pop up when starting Code Warrior 10.6?  The evaluation version was initially installed.  It has since auto down graded to the "community version".
Ron
BlackNight
Hi Ron,
Simply rename the file <install>\MCU\license.dat to a different name so it is not found.
I hope this helps,
Erich
BlackNight
Hi Ron,
I hope this helps,
Erich
ronaldpatton
Yes, that did the trick,  thanks !
