I am using FRDM KL46Z board with ksdk framework.when i am going to build my project, After main function it is showing error message "NO source available for "0x41c"".
It's look like stack overflow causing the issue but i don't have any idea to resolve it.
please help if any one have idea about this error.
I have attached print screen of result and logs of console while building.
Suresh Kumawat
Original Attachment has been moved to: consol_logs_kl46z.txt.zip
Hi Suresh Kumawat
Could you attach your project here, so I can reproduce your issue in my side
