Hi, all.
Nowdays i'm using the I.MX28.
It is my first time to using LINUX and DSP. So i haven't the concept of these things.
I already read MCIMX28 Reference manual about bootmodes. But it was hard to understanding to me.
What i didn't understand is FCB and DBBT.
How to use these things? I found that FCB and DBBT are related with U Boot and kobs ng.
But i don't have idea of U Boot and Kobs ng.
Please tell these things and relationship between U Boot and Kobs ng.
Thank you.
Solved! Go to Solution.
Hi Eunseok
FCB is written to nand by kobs-ng linux tool and DBBT is maintained
automatically by linux NAND GPMI flash driver. NAND information
(ID bytes, timings, and dimensions) is stored in MTD tables :
drivers/mtd/nand/nand_ids.c
drivers/mtd/nand/nand_device_info.c
For the NAND to be recognized, it must have an entry in both tables.
There is no special relationship between U-Boot and kobs-ng,
U-Boot is bootloader application (WebHome < U-Boot < DENX ).
Hi Eunseok
Thank you igor.
Where can i find kobs-ng linux tool? And how to use this? I can't find any document about this.
And what is related with MfgTools and kobs-ng tool?
How to use kobs-ng tool? I can't find any documents about this.
Thank you
