hello,
I run the tcpip examples of ksdk on the frdmk64f in kds,but it's can't work ,both of the "eth_to_serial_frdmk64f" and "httpsrv_frdmk64f"
when I run the examples,the the uart is ok and output the "
Application listening on following ip addresses:
IPv4 Address: 192.168.1.202, port:23
but the network interface seems can't connent,
should I close some correct jumper settings?
ButI don't found any jumper setting in "MQX Getting started" document
Solved! Go to Solution.
Hello Wang,
There is readme file located in <KSDK_PATH>\middleware\tcpip\rtcs\examples\httpsrv and <KSDK_PATH>\middleware\tcpip\rtcs\examples\eth_to_serial that lists the steps needed to run the example.
In this file, step 3 says:
3) Connect the evaluation board and your PC to same Ethernet network.
This instruction requires to do next steps:
I hope this can help you
Isaac
Hello Wang,
Isaac
