VPU memory description structure from vpu_io.h
Question asked by thalex on Sep 1, 2015
Latest reply on Sep 3, 2015 by igorpadykov
I am using i.MX6 VPU for some video processing applications running under Linux.
Here is an extract from vpu_io.h :
typedef struct vpu_mem_desc {
  int size; /*!requested memory size */
  unsigned long phy_addr; /*!physical memory address allocated */
  unsigned long cpu_addr; /*!cpu addr for system free usage */
  unsigned long virt_uaddr; /*!virtual user space address */
} vpu_mem_desc;
I would like to know what exactly is cpu_addr, when and by whom it is used.
Where should i localize it in the management system described here: ARM® Developer Suite Developer Guide 7.5.1. Virtual to physical address mapping (Are phy_addr and virt_uaddr corresponding to virtual memory and physical memory addresses this document is referring to?)
Is cpu_addr would be used in a bare metal system, with no OS?
I hope my question is clear enough...
Alex
