Hello 宗標 廖,
The repository in which the different versions of eglibc is on the link below, you will find the source code for eglib there:
Hello gusarambula
Thank you for your reply.
Is there any patch from FSL for eglibc?
If there is not, I will use this source code.
If there are patches, please offer to me.
Thank you very much!
ZongbiaoLiao
Hello 宗標 廖,
There is no patch for eglibc that I know of. I would recommend using this source code. I hope it helps!
