Source window in Real-Time Debugger CW6.1
Discussion created by Guest on Jan 16, 2008
Latest reply on Jan 30, 2008 by David Payne
Can anyone explain what the Source window is for in Real-Time Debugger? Everytime I click on debug its empty and the only file I can load is main.dbg, however I have seen my asm file appear on the Source window automatically after I click on debug once just like in the Full chip simulation mode.
I suspect having your asm code to appear in the Source window after you click on debug is what's meant to happen if CW is running correctly? (My project is Absolute asm)
Is it normal/correct to have the Source window empty after you click on debug?
Thanks!
