example code for etpu
rajiilangovan
hi friend,
i need a code for generating delay using eTPU in MPC5644A. So Please send me a simple code for my understanding.
davidtosenovjan
I think that eTPU function that would simply delay input signal (if it is the meaning of this question) does not exist.
Probably it would be possible to perform this task with using of external interrupt (SIU module) that would initiate host service request to eTPU channel having assigned output compare function (General Timing Set, OC function).
Here is the list of eTPU functions prepared by Freescale:
http://www.freescale.com/webapp/etpu/
