to use ramdisk
to use ramdisk
himalimunshi
how to use ramdisk as android system partition?
Labels (3)
himalimunshi
I did not get answer for this question.
thanks,
himali
gary_bisson
Senior Contributor III
Hi Himali,
Why would like the system partition to be a ramdisk? As its name suggest, the ramdisk will be located in RAM, the system partition takes about 300MB which is the amount you'll lose. Plus be aware of the ramdisk size limitation: https://www.kernel.org/doc/Documentation/blockdev/ramdisk.txt
If you really want to do so, I'd say to have one ramdisk which would be rootfs + system partition. Then you'd need to modify fstab not to mount /system as already present. But once again I'm very curious about the reason that makes you think this is a good idea.
Gary
himalimunshi
thanks gray bisson
can you share your image and modification detail? i want to fix ext4 file system error
regards,
himali
gary_bisson
Hi Himali,
No I haven't done it, I was just providing hints at a possible implementation. But what do you mean "fix ext4 file system error"? The /system partition should be mounted as read-only at all time which should not get errors at all (no write operation).
Gary
