No Bootloader activity after saving NAND Env
Question asked by carlo val gocela on Aug 25, 2015
Latest reply on Aug 28, 2015 by carlo val gocela
Hello
I have some problem where the bootloader no longer works after saving the setenv in nand.
Below is my procedure:
Board: PCM052
1 Erase NAND Flash
    =>nand erase.chip
2. Load U-boot
    =>fatload mmc 0:1 0x80400000 u-boot.nand
    =>nandwrite 0x80000 0x80400000 0x3DAA0
3. reset your board (For the Phytec phyCORE Vybrid, the "Boot" switches 1, 2, and 5 should be set to On).
4. Booting Kernel/RFS from NAND Flash
    =>fatload mmc 0:1 0x80010000 uImage-3.0-ts-armv7l
    =>nand write 0x80010000 0x100000 0x2491A4
5. set to BOOT from SD
6. Writing RFS to NAND Flash
    => setenv bootcmd fatload mmc 0:1 0x81000000 uImage-3.0-ts-armv7l\;bootm 0x81000000
    => setenv bootargs mem=256M console=ttymxc1,115200 root=/dev/mmcblk0p2 rw rootwait mtdparts=NAND:0xe0000(U-boot),0x20000(U-boot_env),0x500000(Kernel),0x14000000(RFS),-(DATA)
7. boot
8. Write RFS
    #nandwrite /dev/mtd3 rootfs.jffs2
9. poweroff and removed SD Card
10. set set env and boot
    =>setenv bootargs mem=256M console=ttymxc1,115200 rootfstype=jffs2 root=/dev/mtdblock3 rw rootwait mtdparts=NAND:0xe0000(U-boot),0x20000(U-boot_env),0x500000(Kernel),0x14000000(RFS),-(DATA)
    =>setenv bootcmd 'nand read 0x80010000 0x100000 0x2491a4; bootm 0x80010000'
    =>boot
11. reboot and repeat step 10 to check if still boot from NAND
        Result: booted the Linux Kernel
11. reboot and save env
    =>saveenv
    -- Reboot Board
           Result: bootloader no longer loads.
After performing Step 11 the bootloader no longer work.
Any ideas what is wrong when i perform step 11.
Original Attachment has been moved to: saveenv.zip
