How to set IOMUXC_UART2_UART_RX_DATA_SELECT_INPUT
Question asked by Takashi Takahashi on Aug 25, 2015
Latest reply on Aug 25, 2015 by igorpadykov
Hi community.
Our customer has below question.
Description of IMX6DQ RM of 36.4.581 Select Input Register.
In bit # 2-0 of IOMUXC_UART2_UART_RX_DATA_SELECT_INPUT,
There is the following description.
110 SD4_DATA4_ALT2 - Selecting ALT2 mode of pad SD4_DAT4 for UART2_RX_DATA.
111 SD4_DATA7_ALT2 - Selecting ALT2 mode of pad SD4_DAT7 for UART2_TX_DATA.
This register is set UART2 RX Data registers I think, why is TX Data items?
I want to set with  The RX of UART2 is SD4_DATA4_ALT2 and  The TX is SD4_DATA7_ALT2.
And I would like to set in this register bit #2-0 = 0b110 .Is this correct ?
