How to solve the problem about adb?
pengxingwei
Dear all,
          I came cross a problem about adb.
the problem:
root@sabresd_6dq:/ # adb logcat
* daemon not running. starting it now on port 5038 *
ehci_fsl_bus_resume begins, Host 1
* daemon started successfully *
ehci_fsl_bus_resume ends, Host 1
- waiting for device -
and
root@sabresd_6dq:/system/app # adb install myserial.apk
error: device not found
how to solve the problem? Thanks !
Labels (2)
Yuri
Hello !
  Please try solution from the following thread :
i.MX6DL Driver and Getting Windows 7 To Communicate As An Android Device
Yuri
pengxingwei
Hello,where I can find the android_usb_fsl.zip?
pengxingwei
now,my IMX6Q-SDB has not a screen,IIcan only operate it through the console.so how should I do?
pengxingwei
sorry,I don't really understand .
Yuri
Is the ADB working ?
"The versions later than Android JB 4.2.2 introduce public key authentication
policy when connecting to PC host via ADB. This feature will keep ADB offline
until the device and PC pass authentication."
Please refer to "Android_Frequently_Asked_Questions.pdf" in FSL Android documentation.
Yuri.
pengxingwei
Hello,whether we can set the USB debugging method throght command line ?if can ,what command can be use ?
Thank you !
pengxingwei
how to solve it ? Thank you !
pengxingwei
hello, because my board hasn't lcd screen ,then whether the following step can't  operate?
5. Enable the "USB debugging" option on the i.MX6 device
System settings -> Developer options -> USB debugging
