About Power Group of i.MX6SoloLite
yuuki
Senior Contributor II
Dear all,
We use i.MX6SoloLite.
We check the Power group of each pin.
We found difference between i.MX Pin Mux Too and Datasheet.
In i.MX Pin Mux Too, the power group of LCD is NVCC_LCD.
However, in Datasheet, this power group is NVCC33_IO or NVCC18_IO.
We understand that the description of the data sheet is right.
Is our understanding right?
Yuuki
Hi Yuuki
you are right, as NVCC_LCD was renamed to NVCC33_IO or NVCC18_IO
according to revision history description from datasheet
Hi Yuuki
