Hello
This is the way the project change wizard is implemented today.
You can submit a Change Request through our on-line support web page and ask to get a modification in the project change wizard.
Click
here to submit a Change Request.
Some additional information on that.
When you are using the project change wizard, the files, which have been changed, are stored in a zip file with _backup in his name.
So you should be able to retrieve the original file from that archive.
Finally there might also be some .mem file created when you are debugging on real hardware.
Format of the .mem file are completely different between simulator & real time debugger.
So the change wizard is correct when it modifies the default.mem file.
CrasyCat
