Hu Yang
i want to program flash,but FAILED(MPC8349)
Discussion created by Hu Yang on Jan 2, 2008
Latest reply on Aug 29, 2012 by Tomasz Pasternak
Environment
    Winddow XP
    CW Power Architecture 8.7
Hardware
    MPC 8349EA
    USB TAP
Set up
    Init file in attachment
    Target mem   0x007FF000
    Size               0x00006000
    Flash S29GL256N   16Mx16x1 base @ 0xF8000000
Try to do
    blank check
    program
            FAILED
Status Error:  Initialization Failed.
Flash Programmer Log
Using Algorithm: flash_image.bin
my board is designed by myself, i used the Init file "8349ITX_init.cfg",because my board is like it.
i want to know whether the reason of this error is the improper Init file? i need to modify this file?
THANKS!
