How to download the application to the i.MX6Q-SDB development board?
pengxingwei
Dear all,
          Hello,I had a apk of android,How to download the apk to the i.MX6Q-SDB development board?
Labels (2)
Hi peng
as for loading apk with adb help one can look at
Using ADB with your Sabre Board
http://2012ftf.ccidnet.com/pdf/0066.pdf
saurabh206
Senior Contributor III
Hi Peng
Following solutions to install apk on SDB board.
You can copy apk using USB driver. Or using ADB connection.
you can install your application.
Saurabh
pengxingwei
Hi Saurabh,
         Copying apk using USB driver ?
saurabh206
Hi Peng,
It typo error,
Copy you apk to USB disk, and connect USB disk to SDB boad.
And install apk.
Saurabh
