Add the 6 pin header, get a 6 pin IDC cable, and you are ready to rock.
It is a a full P&E BDM and will work with CFV1, S08 and S(X)12 boards.
However, do not expect it to supply power to the board. I have been told it is also not as well protected and a USB 12 is - not sure what that means.
