How much size is required for download algorithm in code warrior hardware diagnostic tool?
karunakaranradh
I am planning to use the inbuilt 512KB SDRAM of T2080 as a target CPU in code warrior hardware diagnostic tool.
How much memory is required to download the algorithm to run the hardware diagnostic tool?
Karunakaran R
addiyi
The flash programmer algorithm required a maximum 30k.
Adrian
addiyi
Adrian
karunakaranradh
Hi Adrain,
I configured the SDRAM in code warrior script  and set the SDRAM address as download algorithm address. With is configuration, i performed the 256MB of DDR3 memory test. it was working fine and faster also when compare with DDR3 set as download algorithm.
Thanks for your information.
Karunakaran R
