BSP i.MX6 Linux L3.14.28_1.0.0-ga ->Unknown module(s) in QT: multimedia webkitwidgets
haibohe
Use qt creator 3.4.2 Compile the project
QT version: Fsl-release-bsp/build-wayland/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/qtbase/5.3.2-r0/build/bin/qmake
arm gcc: /opt/arm/arm-linux-gcc-4.9/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++
qt creator 3.4.2 prompt:Unknown module(s) in QT: multimedia webkitwidgets
How to compile multimedia and webkitwidgets,thanks
jamesbone
Hello Haibo,
You need to review some documentation from QT, here is a link regarding the webkit,
Qt WebKit Widgets | Qt 5.5
Qt5 Webkit Tutorial : Web Browser with QtCreator using QWebView - 2015
haibohe
Can't find the answer here.
