P1020RDB-PD: UBoot in SD card
abdurrehman
Does P1020RDB-PD support loading bootloader(uboot) from SD card?
If so, what are the switch settings to load uboot from SD card?
I am using FSL SDK 1.8. The documentation lists the procedure to burn UBoot in SD card but does not say what switch settings to use.
Abdur Rehman
addiyi
Please refer to Freescale Infocenter for more information.
Adrian
addiyi
Adrian
Mtvjdhfchh
can you offer p1020 SCH PCB BOM?
