551x Exception recording
markelson
My application has the ability to record data to non-volatile memory. I am trying to determine which registers etc are best to record to diagnose what happened in the event of a processor exception (e.g. as caused by a divide-by-zero). The ESR, MCSR and DEAR look like obvious ones. What else would be recommended? Is there any existing guidance on this, e.g. an AN?
TIA, Mark
davidtosenovjan
It is explicitly stated in chapter 5.7 Interrupt Definitions in core reference manual and it is different for every particular exception:
http://cache.freescale.com/files/32bit/doc/ref_manual/e200z1RM.pdf
http://cache.freescale.com/files/32bit/doc/ref_manual/e200z0RM.pdf
It says which register are being written during exception and which are untouched.
For instance:
IVOR0 writes CSRR0, CSRR1 and MSR
IVOR1 writes CSRR0, CSRR1, MSR and MCSR
and so on…
davidtosenovjan
For instance:
and so on…
markelson
David,
That's the extra info I needed - I'd been looking in the 5510RM only.
Thank you,
Mark
