We have a ongoing project with k30 MCU, board is our design. The software is task based constructed.
We have already done all the drivers, application part of the software and a simple function that allows to use all that in task call manner.
Now it would be better to use MQX RTOS to replace our simple task call mechanism.
How can i adapt MQX to our project? We are working with Kinetis Design Studio 3.0
Is there an example project in KDS for MQX, which i can extend and add my tasks functions?
Is there a document or tutorial how to build simple MQX project in KDS?
MQX™ Software Solutions are available in three variants to meet your embedded design needs: traditional MQX RTOS; MQX Lite; and MQX RTOS for Kinetis SDK.
Are you interested for traditional MQX RTOS?
In this case you need to create a BSP for your board, the attached document shows how to do this.
In addition it is necessary to add the drivers, the following document shows an example How to Make a new MQX Driver
Sol
