3PHASELV-KIT Quick Start Instructions
datamstr
Hello all,
I unboxed my Freescale 3PhaseLV-Kit and reviewed the files on the CD. Is there a quick start guide for this kit? Also, I assume that firmware has already been programmed at the factory.
Thanks for your help!
David
david_diaz
Hello David,
You can find all the documentation related to the 3PHASELV-KIT at the following link:
3-Phase BLDC/PMSM Low-Voltage Motor Control|Freescale
In case you are interested in its documentation, please refer to the Documentation tab as the following figure:
Please let me know if this information is useful for you.
I am glad to help. :smileyhappy:
David Diaz
datamstr
Hello David,
I found a short setup guide (Section 1.4), but it did not help much for getting everything up and running. It looks like FreeMaster is required to get the motor spinning, but complete instructions seem to be missing. Also, I am not very familiar with FreeMASTER.
Do you have any other information about running the kit?
David
