I need to know is it possible to transmit 1080p30 signal over single channel LVDS over LVDS-to-HDMI converter (Chrontel CH7036) to get 1080p30 output on HDMI.
I know it's not possible to transmit 1080p30 @ 60Hz with single channel LVDS, but maybe it's possible to transmit 1080p30 @ 30Hz ?
Solved! Go to Solution.
Hi Yevhen
single channel supports up to WXGA, with IPU data rate up to 85 MHz, as described in p.71
A Deep Dive into Image Processing for i.MX 6 Series Applications Processors
so seems 1080p30 may be supported.
Hi Yevhen
