We are using FRDM K64F evaluation board.
Using KDS 3.0.0 and KSDK 1.2.0. Using MQXRTOS in KSDK
In our project,i want to read multiple adc channels.
Using the pins PTB2,PTB3(ADC0) and PTB10,PTB11(ADC1).
But currently i can only read PTB2 & PTB10 values, ie single channels from each modules.
we are blocked in this
Can any one help me to solve this problem.
configuration codes are copied below:::::::::::::::::::::::::::::::::::::::
configuration for adc0(therm1):
const adc16_converter_config_t therm1_InitConfig0 = {
.lowPowerEnable = false,
.clkDividerMode = kAdc16ClkDividerOf1,
.longSampleTimeEnable = false,
.resolution = kAdc16ResolutionBitOfSingleEndAs12,
.clkSrc = kAdc16ClkSrcOfBusClk,
.asyncClkEnable = false,
.highSpeedEnable = false,
.longSampleCycleMode = kAdc16LongSampleCycleOf24,
.hwTriggerEnable = false,
.refVoltSrc = kAdc16RefVoltSrcOfVref,
.continuousConvEnable = true,
.dmaEnable = false,
const adc16_converter_config_t therm1_InitConfig1 = {
.resolution = kAdc16ResolutionBitOfSingleEndAs8,
.dmaEnable = false,
const adc16_hw_cmp_config_t therm1_HwConfig0 = {
const adc16_chn_config_t therm1_ChnConfig1 = {
.chnIdx = kAdc16Chn13,
.convCompletedIntEnable = false,
.diffConvEnable = false
const adc16_chn_config_t therm1_ChnConfig0 = {
.chnIdx = kAdc16Chn12,
/* END therm1. */
configuration for adc1 module(universal)
const adc16_converter_config_t universal_InitConfig0 = {
.dmaEnable = false,
const adc16_converter_config_t universal_InitConfig1 = {
.dmaEnable = false,
const adc16_chn_config_t universal_ChnConfig0 = {
.chnIdx = kAdc16Chn14,
const adc16_chn_config_t universal_ChnConfig1 = {
.chnIdx = kAdc16Chn15,
/* END universal. */
task1()
while(1)
//Read Analog Inputs
ADC16_DRV_ConfigConvChn(FSL_THERM1,1,&therm1_ChnConfig0);
ADC16_DRV_WaitConvDone(FSL_THERM1,0);
value1=ADC16_DRV_GetConvValueSigned(FSL_THERM1,0);
PRINTF("ADC1 value is %d\n",value1);
ADC16_DRV_ConfigConvChn(FSL_THERM1,1,&therm1_ChnConfig1);
DelayFunction ();
ADC16_DRV_WaitConvDone(FSL_THERM1,1);
value2=ADC16_DRV_GetConvValueSigned(FSL_THERM1,1);
PRINTF("ADC2 value is %d\n",value2);
ADC16_DRV_ConfigConvChn(FSL_UNIVERSAL,1,&universal_ChnConfig0);
ADC16_DRV_WaitConvDone(FSL_UNIVERSAL,0);
value3=ADC16_DRV_GetConvValueSigned(FSL_UNIVERSAL,0);
PRINTF("ADC3 value is %d\n",value3);
ADC16_DRV_ConfigConvChn(FSL_UNIVERSAL,1,&universal_ChnConfig1);
DelayFunction ();
ADC16_DRV_WaitConvDone(FSL_UNIVERSAL,1);
value4=ADC16_DRV_GetConvValueSigned(FSL_UNIVERSAL,1);
PRINTF("ADC4 value is %d\n",value4);
What may be the fault in this procedure................Waiting for a solution asap..
RAHUL
Hello RAHUL,
Here :
the parameter of "uint32_tchnGroup " , i think is 1 , for in the ADC16_DRV_ConfigConvChn function , you have choose "1" .
It is the same about ADC1 .
Hope it helps
Alice
Thanks Alice_Yang
while resetting the parameters passed, its worked for me.
I think parameter of "uint32_tchnGroup" is same for all channels in one module
Parameter value will change for the next adc module.
while(1)
ADC16_DRV_ConfigConvChn(FSL_ADC1,0,&adc1_ChnConfig0);
value=ADC16_DRV_GetConvValueRAW(FSL_ADC1,0);
printf("value=%d",value);
ADC16_DRV_ConfigConvChn(FSL_ADC1,0,&adc1_ChnConfig1);
value2=ADC16_DRV_GetConvValueRAW(FSL_ADC1,0);
printf("value=%d",value2);
ADC16_DRV_ConfigConvChn(FSL_ADC2,0,&adc2_ChnConfig0);
value3=ADC16_DRV_GetConvValueRAW(FSL_ADC2,0);
printf("value=%d",value3);
ADC16_DRV_ConfigConvChn(FSL_ADC2,0,&adc2_ChnConfig1);
value4=ADC16_DRV_GetConvValueRAW(FSL_ADC2,0);
printf("value=%d",value4);
It worked for me now...Not sure whether it may misbehave in future......
Rahul
