MKW24D512 Jlink program flash,now I can read all sectors in flash,but i can't write them,prompt flash is write-protected, how to deal it,program flash aggain
Hello Lee,
Did you use IAR EWARM IDE to flash the WirelessUART project? Please specify the process you followed to program the boards. In case flash is secured, you could easily unsecure it using Jlink commander utility.
Please refer to the following post and try such approach. Let me know if that solved the problem.
Link: https://community.freescale.com/message/473258
AngelC
