I would like to know if there is any support for MIL_STD 1553 bus for imx6. MIL-STD 1553 is a bus used in the military domain and from what I've read there could be MIL-STD 1553 modules plugged on a PCI card or PCMCIA cards or it could be a native interface like PMC, PXI or VXI.
In case support for MIL_STD 1553 PCI or PCMCIA card is needed, what would I need besides PCI or PCMCIA driver support ? Is there a MIL-STD 1553 driver available ? I didn't find anything.
Has anyone came across this situation until now or could point me where to look for documentation?
Thank you,
Mihaita Ivascu
Hi Mihaita
i.MX6 do not support MIL-STD 1553 natively in hardware, however
as you correctly noted, one can use mPCIe cards integrating 1553 interfaces.
Usually MIL-STD 1553 drivers (or its sources) are provided by card vendors,
they are not available in standard BSP distribution.
Hello Igor,
Thanks for the information. In case native MIL-STD 1553 card (PXI, PMC or VXI interfaces) is used I suppose a completely new driver for that specific chip needs to be written. Is that correct ?
Thank you,
Mihaita
Hi Mihaita
I think you are right.
Datasheet and Reference manual here.
Hello Biyong,
I looked there before posting the question and saw there was no reference to MIL-STD 1553 bus. I wanted to make sure that maybe I'm missing something.
Thank you,
Mihaita
