hi ,
i am working on controlling blinking of LED using PWM , so how do i generate two different freq in two diff channel. I could generate single freq in a single channel but not different freq. Is it possible ? if yes how do i go about ??
jashan
See page 18 of
http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
Each TPM has a single clock, so all channels of a TPM have the same frequency.
To generate different frequencies you need to use outputs from different TPMs.
Mark
Kinetis: µTasker Kinetis support
KEA: µTasker TRK-KEA8 support / µTasker TRK-KEA64 support / µTasker TRK-KEA128 support
PWM: http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
For the complete "out-of-the-box" Kinetis experience and faster time to market
