Code warrior had a problem doing an automatic update
gerryk
Where do I send the diagnostics file with details of the error?
Tags (2)
Carlos_Mendoza
Hi Gerry,
You can attach the diagnostic information here or you can send it to us through a Service Request, you can create one here:
Sales and Support|Freescale
Regarding your problem when updating CodeWarrior, I think that the following post created by our colleague Erich Styger might be helpful for you:
Workaround for “Installing Software has encountered a problem” in Eclipse | MCU on Eclipse
Hope it helps!
Carlos Mendoza
Technical Support Engineer
