Entering Run Mode in QG8?
Discussion created by Guest on Dec 15, 2007
Latest reply on Dec 16, 2007 by Guest
Hi guys,
I was wondering if anyone know of an easiest way to enter the run mode upon Power-on reset (POR)? It seems that I would need a timer switch debounce circuit to keep the BKGD/MS pin high when power on and then debounce the switch in order to make use of the pin for output.
Would be greatly appreciated if someone put me on the right track.
Thanks!
