mmc0: Timeout waiting for hardware interrupt
vineethhegde
Hai...
I am using i.MX6Q based board. Schematics is similar to the Sabre SD board. i got a error message as shown below.
Please suggest a solution.
Hi vineeth113
seems sd port is not working correctly. Since you are using customizing BSP,
recommended to test board with Freescale BSP or with SDK. Also check signals
with oscilloscope, connecting to port sd card.
