MC9S12XEP100 Emulate EEPROM
Question asked by eric grandidier on Aug 4, 2015
I use the Library IEE1.C generate by PE to write and read in the Emulate EEPROM.
At the beginning there is no problem.
But after several months writing becomes impossible.
I send you the file
The date to store are in the SAUV_RAM segment in RamEEProm.c
The procedure char sauv_config()  in Eepromx.c
The procedure for retrieving data is bool rappel_config() in Eepromx.c
I use the version 5.9.0 of Code Warrior
Mask 5M48H
Have you an idea about the problem ?
Original Attachment has been moved to: 0330&Boot_V1.prm.zip
Original Attachment has been moved to: IEE1.h.zip
Original Attachment has been moved to: IEE1.c.zip
Original Attachment has been moved to: RamEEprom.c.zip
Original Attachment has been moved to: Eepromx.c.zip
