Error : invalid offset, value too big
camilovf
Hi all,
I am currently working on a projet, coding in ARM code, on a KE04z (48 MHz) micro-controller 8K flash.
When i reach a certain code length (arround 1000 lines) the error message appears for the first lines of the code (as shown in the picture bellow).
By looking for an answer, I found that the problem may be due to pointer's adresse offset too big.
Do you know how to solve this probleme? I seems the problem is related to code lenght, but is there a way to correct it without erasing the excess of code lines?
Thank you for your help,
Camilo Vega Farfan
Carlos_Musich
Hi Camilo,
could you share a simple project where we can reproduce this behavior?
Thanks!
Carlos
