Hi ghecu,
we used to face the same problem. This is how we solved it.
Just 'cancel' while programming, do program again, till 'Connecting TAP' pop window appears. Next time it would write.
If not, try restarting CW.
I dont know if it is the right way of solving it, but we found it working.
ghecu wrote:
Environment
Winddow XP
CW Power Architecture 8.7
Hardware
MPC 8349
USB TAP
Set up
Init file in attachment
Target mem 0x007FF000
Size 0x00006000
Flash 28F320J3 2Mx16x1 base @ 0xFFC00000
Try to do
Calculate Checksum
Memory Range on Target
Start 0x00010000
Size 0x10000
FAILED
Try to do
Erase Flash
Range 0xFFD00000 0xFFD1FFFF
FAILED
Status Error: Initialization Failed.
Flash Programmer Log
Using Algorithm: intel16x1j3.elf
=== Target Configuration Settings
=== Connection: CodeWarrior USB TAP
=== Target Processor: 8349
=== Target Init File: C:\8349\flash_mpc8349_reva_linux_registers.cfg
Connecting...
Timestamp: Fri Dec 7 16:22:51 2007
Protocol Log
CCS: 0000 : ccs_open
CCS: : ipaddr = 127.0.0.1
CCS: : port = 41475
CCS: : timeout = 60
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 10
CCS: : Error message:
Connection refused
CCS: : port = 41475
CCS: : timeout = 60
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 0
CCS: 0000 : ccs_get_connection_count
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_get_connection_count; ccs_error = 0
CCS: 0000 : ccs_available_connections
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_available_connections; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_delete_cc
CCS: : serverh = 0
CCS: : count = 0
CCS: : ccs_delete_cc; ccs_error = 0
CCS: 0000 : ccs_config_cc
CCS: : serverh = 0
CCS: : config_string = utap:0
CCS: : ccs_config_cc; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_set_timeout
CCS: : serverh = 0
CCS: : timeout = 10
CCS: : ccs_set_timeout; ccs_error = 0
CCS: : serverh = 0
CCS: : timeout = 10
CCS: 0000 : ccs_supported_connections
CCS: : serverh = 0
CCS: : count = 12
CCS: : ccs_supported_connections; ccs_error = 0
CCS: 0000 : ccs_get_config_chain
CCS: : serverh = 0
CCS: : device_list: (size = 0)
CCS: : ccs_get_config_chain; ccs_error = 0
CCS: 0000 : ccs_config_chain
CCS: : serverh = 0
CCS: : cc = 0
CCS: : device_list: (size = 1)
CCS: : device[0]:: core_type=55; device_descr=[ir_length:0;dr_bypass_length:0;bypass_instruction:0]
CCS: : ccs_config_chain; ccs_error = 0
CCS: 0000 : ccs_set_max_tck
CCS: : coreh = [serverh:0;cc_index:0;chain_pos:0]
CCS: : khz = 4030
CCS: : ccs_set_max_tck; ccs_error = 0
CCS: 0000 : ccs_send_message
CCS: : message = 3
CCS: : ccs_send_message; ccs_error = 0
