Hello
If you wish to program your application from CodeWarrior into flash, just make sure you are using
Multilink/CyclonePro as connection and then build your application and press the debug button.
The application to be debugged will be automatically programmed into flash.
Be careful, CodeWarrior is not a production flash programming tool.
It is a development software allowing you to build and debug applications.
If you are looking for a production flash programming tool, you need to look for other alternatives.
I know P&E and Softec have such tools available.
Might be other out there.
I hope this helps.
CrasyCat
