Hello
There are other commands available that you can use to print only the value of a specific variable.
Command e (for evaluate) can be used.
For instance
e fiboCount
will print value of variable fiboCount in the command window
If you are looking for something you can format yourself, you can use the command printf.
printf ("fiboCount= %d", fiboCount)
will print fiboCount = 5 for example in the command window.
Please refer to {Install}\Help\PDF\Debugger_HC12.pdf Chapter "Book IV: Commands" for more information about commands and their syntax.
I hope this helps.
CrasyCat
