Sensor fusion: commercial support?
seankelleher
Is commercial support available for the open-source sensor fusion code?  On non-Freescale hardware?
If so, is it subject to purchasing some minimum block of hours or can it be bought on a per-issue basis?
Integration of the code is so far pretty painless, but I want to provide the options to my client.
Sean
sinanakman
Senior Contributor III
Sean, if you or your client considers help
from third parties (FSL partners)
please let me know.
Sinan Akman
michaelestanley
Not at this time.
seankelleher
Thanks for the prompt response!
