boot trace32 script setup law for memory controller
viktorkarlsson
I use a P1020RDB_PD devkit. For debugging i use Laterbach trace32 probe.
My goal is to boot VxWorks 653 hopefully using U-boot.
To make one thing at the time my first goal is setup HW with a probe script.
Secondary load at program to ram and execute it.
Here come the first issue.
When I enable the Law for the memory controller I lose communication between the probe and the CPU.
The script is attached. I´ve taken most of the values from the U-boot setup.
I need a extra pair of eyes for this problem.
/V
Original Attachment has been moved to: bootInitP1020RDB_stripped.cmm.zip
viktorkarlsson
Okey I found a initscript on Lauterbach website. with a few modifications I seems to work.
/V
