mc9s12xep100 linker problem
kikimorisato
i installed codewarrior compiler(mc9s12xep100) and i used gnumake.
and used license usb dongle.
Simple program is not a problem because enough the first flash page.
The linker problems appear in the use of second flash page.
It used the first flash page again.
and display error
here is my linker command line and error message
... is clipping message
C:\Freescale\CWS12\Prog\linker.exe -Feo -B -M -LC:\Freescale\CWS12\lib\HC12c\lib -Addansibf.lib -L -O../CANTEST_S20150729.elf CANTEST_S20150729.prm
Command Line: '-Feo -B -M -LC:\Freescale\CWS12\lib\HC12c\lib -Addansibf.lib -L -O../CANTEST_S20150729.elf CANTEST_S20150729.prm'
Linking D:\Work\20150729\CANTEST_S20150729\CANTEST_S20150729.prm
Reading file 'ansibf.lib'
Reading file 'D:\Work\20150729\CANTEST_S20150729\Start12.o'
Reading file 'D:\Work\20150729\CANTEST_S20150729\datapage.o'
Reading file 'D:\Work\20150729\CANTEST_S20150729\mc9s12xep100.o'
Reading file 'D:\Work\20150729\CANTEST_S20150729\Vectors.o'
Reading file 'D:\Work\20150729\CANTEST_S20150729\CANTEST_S20150729.o'
ERROR L1102: Out of allocation space in segment PAGE_C0 at address 0xC080C8
Generating MAP file 'D:\Work\20150729\CANTEST_S20150729\CANTEST_S20150729.map'
SmartLinker: *** 1 error(s), 0 warning(s), 0 information message(s) ***
*** command line: '-Feo -B -M -LC:\Freescale\CWS12\lib\HC12c\lib -Addansibf.lib -L -O../CANTEST_S20150729.elf CANTEST_S20150729.prm' ***
SmartLinker: *** Error occurred while processing! ***
gnumake: *** [../CANTEST_S20150729.elf] Error 1
here is my prm
NAMES
    {Start12.o}
    {datapage.o}
    {mc9s12xep100.o}
    {Vectors.o}+
END
SEGMENTS /* here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. All addresses are 'logical' */
    SOFTVTABLE = READ_WRITE 0x1000 TO 0x10FF;
    VECTOR_TABLE = READ_ONLY 0xFF10 TO 0xFFFF;
/* Register space  */
/*    IO_SEG        = PAGED                            0x0000 TO   0x07FF; intentionally not defined */
/* non-paged EEPROM */
      EEPROM        = READ_ONLY   DATA_NEAR IBCC_NEAR  0x0C00 TO   0x0FFF;
/* non-paged RAM */
      RAM           = READ_WRITE  DATA_NEAR            0x2000 TO   0x3FFF;
/* non-banked FLASH */
      ROM_4000      = READ_ONLY   DATA_NEAR IBCC_NEAR  0x4000 TO   0x7FFF;
      ROM_C000      = READ_ONLY   DATA_NEAR IBCC_NEAR  0xC000 TO   0xFEFF;
/* paged EEPROM                                        0x0800 TO   0x0BFF; addressed through EPAGE */
      EEPROM_00     = READ_ONLY   DATA_FAR IBCC_FAR  0x000800 TO 0x000BFF;
      EEPROM_01     = READ_ONLY   DATA_FAR IBCC_FAR  0x010800 TO 0x010BFF;
      EEPROM_02     = READ_ONLY   DATA_FAR IBCC_FAR  0x020800 TO 0x020BFF;
      EEPROM_03     = READ_ONLY   DATA_FAR IBCC_FAR  0x030800 TO 0x030BFF;
      EEPROM_04     = READ_ONLY   DATA_FAR IBCC_FAR  0x040800 TO 0x040BFF;
      EEPROM_05     = READ_ONLY   DATA_FAR IBCC_FAR  0x050800 TO 0x050BFF;
      EEPROM_06     = READ_ONLY   DATA_FAR IBCC_FAR  0x060800 TO 0x060BFF;
      EEPROM_07     = READ_ONLY   DATA_FAR IBCC_FAR  0x070800 TO 0x070BFF;
      EEPROM_08     = READ_ONLY   DATA_FAR IBCC_FAR  0x080800 TO 0x080BFF;
      EEPROM_09     = READ_ONLY   DATA_FAR IBCC_FAR  0x090800 TO 0x090BFF;
      EEPROM_0A     = READ_ONLY   DATA_FAR IBCC_FAR  0x0A0800 TO 0x0A0BFF;
      EEPROM_0B     = READ_ONLY   DATA_FAR IBCC_FAR  0x0B0800 TO 0x0B0BFF;
      EEPROM_0C     = READ_ONLY   DATA_FAR IBCC_FAR  0x0C0800 TO 0x0C0BFF;
      EEPROM_0D     = READ_ONLY   DATA_FAR IBCC_FAR  0x0D0800 TO 0x0D0BFF;
      EEPROM_0E     = READ_ONLY   DATA_FAR IBCC_FAR  0x0E0800 TO 0x0E0BFF;
      EEPROM_0F     = READ_ONLY   DATA_FAR IBCC_FAR  0x0F0800 TO 0x0F0BFF;
      EEPROM_10     = READ_ONLY   DATA_FAR IBCC_FAR  0x100800 TO 0x100BFF;
      EEPROM_11     = READ_ONLY   DATA_FAR IBCC_FAR  0x110800 TO 0x110BFF;
      EEPROM_12     = READ_ONLY   DATA_FAR IBCC_FAR  0x120800 TO 0x120BFF;
      EEPROM_13     = READ_ONLY   DATA_FAR IBCC_FAR  0x130800 TO 0x130BFF;
      EEPROM_14     = READ_ONLY   DATA_FAR IBCC_FAR  0x140800 TO 0x140BFF;
      EEPROM_15     = READ_ONLY   DATA_FAR IBCC_FAR  0x150800 TO 0x150BFF;
      EEPROM_16     = READ_ONLY   DATA_FAR IBCC_FAR  0x160800 TO 0x160BFF;
      EEPROM_17     = READ_ONLY   DATA_FAR IBCC_FAR  0x170800 TO 0x170BFF;
      EEPROM_18     = READ_ONLY   DATA_FAR IBCC_FAR  0x180800 TO 0x180BFF;
      EEPROM_19     = READ_ONLY   DATA_FAR IBCC_FAR  0x190800 TO 0x190BFF;
      EEPROM_1A     = READ_ONLY   DATA_FAR IBCC_FAR  0x1A0800 TO 0x1A0BFF;
      EEPROM_1B     = READ_ONLY   DATA_FAR IBCC_FAR  0x1B0800 TO 0x1B0BFF;
      EEPROM_1C     = READ_ONLY   DATA_FAR IBCC_FAR  0x1C0800 TO 0x1C0BFF;
      EEPROM_1D     = READ_ONLY   DATA_FAR IBCC_FAR  0x1D0800 TO 0x1D0BFF;
      EEPROM_1E     = READ_ONLY   DATA_FAR IBCC_FAR  0x1E0800 TO 0x1E0BFF;
      EEPROM_1F     = READ_ONLY   DATA_FAR IBCC_FAR  0x1F0800 TO 0x1F0BFF;
      EEPROM_FC     = READ_ONLY   DATA_FAR IBCC_FAR  0xFC0800 TO 0xFC0BFF;
      EEPROM_FD     = READ_ONLY   DATA_FAR IBCC_FAR  0xFD0800 TO 0xFD0BFF;
      EEPROM_FE     = READ_ONLY   DATA_FAR IBCC_FAR  0xFE0800 TO 0xFE0BFF;
/*    EEPROM_FF     = READ_ONLY                      0xFF0800 TO 0xFF0BFF; intentionally not defined: equivalent to EEPROM */
/* paged RAM:                                          0x1000 TO   0x1FFF; addressed through RPAGE */
      RAM_F0        = READ_WRITE  DATA_FAR           0xF01000 TO 0xF01FFF;
      RAM_F1        = READ_WRITE  DATA_FAR           0xF11000 TO 0xF11FFF;
      RAM_F2        = READ_WRITE  DATA_FAR           0xF21000 TO 0xF21FFF;
      RAM_F3        = READ_WRITE  DATA_FAR           0xF31000 TO 0xF31FFF;
      RAM_F4        = READ_WRITE  DATA_FAR           0xF41000 TO 0xF41FFF;
      RAM_F5        = READ_WRITE  DATA_FAR           0xF51000 TO 0xF51FFF;
      RAM_F6        = READ_WRITE  DATA_FAR           0xF61000 TO 0xF61FFF;
      RAM_F7        = READ_WRITE  DATA_FAR           0xF71000 TO 0xF71FFF;
      RAM_F8        = READ_WRITE  DATA_FAR           0xF81000 TO 0xF81FFF;
      RAM_F9        = READ_WRITE  DATA_FAR           0xF91000 TO 0xF91FFF;
      RAM_FA        = READ_WRITE  DATA_FAR           0xFA1000 TO 0xFA1FFF;
      RAM_FB        = READ_WRITE  DATA_FAR           0xFB1000 TO 0xFB1FFF;
      RAM_FC        = READ_WRITE  DATA_FAR           0xFC1000 TO 0xFC1FFF;
      RAM_FD        = READ_WRITE  DATA_FAR           0xFD1000 TO 0xFD1FFF;
/*    RAM_FE        = READ_WRITE                     0xFE1000 TO 0xFE1FFF; intentionally not defined: equivalent to RAM: 0x2000..0x2FFF */
/*    RAM_FF        = READ_WRITE                     0xFF1000 TO 0xFF1FFF; intentionally not defined: equivalent to RAM: 0x3000..0x3FFF */
/* paged FLASH:                                        0x8000 TO   0xBFFF; addressed through PPAGE */
      PAGE_C0       = READ_ONLY   DATA_FAR IBCC_FAR  0xC08000 TO 0xC0BFFF;
      PAGE_C1       = READ_ONLY   DATA_FAR IBCC_FAR  0xC18000 TO 0xC1BFFF;
      PAGE_C2       = READ_ONLY   DATA_FAR IBCC_FAR  0xC28000 TO 0xC2BFFF;
      PAGE_C3       = READ_ONLY   DATA_FAR IBCC_FAR  0xC38000 TO 0xC3BFFF;
      PAGE_C4       = READ_ONLY   DATA_FAR IBCC_FAR  0xC48000 TO 0xC4BFFF;
      PAGE_C5       = READ_ONLY   DATA_FAR IBCC_FAR  0xC58000 TO 0xC5BFFF;
      PAGE_C6       = READ_ONLY   DATA_FAR IBCC_FAR  0xC68000 TO 0xC6BFFF;
      PAGE_C7       = READ_ONLY   DATA_FAR IBCC_FAR  0xC78000 TO 0xC7BFFF;
      PAGE_C8       = READ_ONLY   DATA_FAR IBCC_FAR  0xC88000 TO 0xC8BFFF;
      PAGE_C9       = READ_ONLY   DATA_FAR IBCC_FAR  0xC98000 TO 0xC9BFFF;
      PAGE_CA       = READ_ONLY   DATA_FAR IBCC_FAR  0xCA8000 TO 0xCABFFF;
      PAGE_CB       = READ_ONLY   DATA_FAR IBCC_FAR  0xCB8000 TO 0xCBBFFF;
      PAGE_CC       = READ_ONLY   DATA_FAR IBCC_FAR  0xCC8000 TO 0xCCBFFF;
      PAGE_CD       = READ_ONLY   DATA_FAR IBCC_FAR  0xCD8000 TO 0xCDBFFF;
      PAGE_CE       = READ_ONLY   DATA_FAR IBCC_FAR  0xCE8000 TO 0xCEBFFF;
      PAGE_CF       = READ_ONLY   DATA_FAR IBCC_FAR  0xCF8000 TO 0xCFBFFF;
      PAGE_D0       = READ_ONLY   DATA_FAR IBCC_FAR  0xD08000 TO 0xD0BFFF;
      PAGE_D1       = READ_ONLY   DATA_FAR IBCC_FAR  0xD18000 TO 0xD1BFFF;
      PAGE_D2       = READ_ONLY   DATA_FAR IBCC_FAR  0xD28000 TO 0xD2BFFF;
      PAGE_D3       = READ_ONLY   DATA_FAR IBCC_FAR  0xD38000 TO 0xD3BFFF;
      PAGE_D4       = READ_ONLY   DATA_FAR IBCC_FAR  0xD48000 TO 0xD4BFFF;
      PAGE_D5       = READ_ONLY   DATA_FAR IBCC_FAR  0xD58000 TO 0xD5BFFF;
      PAGE_D6       = READ_ONLY   DATA_FAR IBCC_FAR  0xD68000 TO 0xD6BFFF;
      PAGE_D7       = READ_ONLY   DATA_FAR IBCC_FAR  0xD78000 TO 0xD7BFFF;
      PAGE_D8       = READ_ONLY   DATA_FAR IBCC_FAR  0xD88000 TO 0xD8BFFF;
      PAGE_D9       = READ_ONLY   DATA_FAR IBCC_FAR  0xD98000 TO 0xD9BFFF;
      PAGE_DA       = READ_ONLY   DATA_FAR IBCC_FAR  0xDA8000 TO 0xDABFFF;
      PAGE_DB       = READ_ONLY   DATA_FAR IBCC_FAR  0xDB8000 TO 0xDBBFFF;
      PAGE_DC       = READ_ONLY   DATA_FAR IBCC_FAR  0xDC8000 TO 0xDCBFFF;
      PAGE_DD       = READ_ONLY   DATA_FAR IBCC_FAR  0xDD8000 TO 0xDDBFFF;
      PAGE_DE       = READ_ONLY   DATA_FAR IBCC_FAR  0xDE8000 TO 0xDEBFFF;
      PAGE_DF       = READ_ONLY   DATA_FAR IBCC_FAR  0xDF8000 TO 0xDFBFFF;
      PAGE_E0       = READ_ONLY   DATA_FAR IBCC_FAR  0xE08000 TO 0xE0BFFF;
      PAGE_E1       = READ_ONLY   DATA_FAR IBCC_FAR  0xE18000 TO 0xE1BFFF;
      PAGE_E2       = READ_ONLY   DATA_FAR IBCC_FAR  0xE28000 TO 0xE2BFFF;
      PAGE_E3       = READ_ONLY   DATA_FAR IBCC_FAR  0xE38000 TO 0xE3BFFF;
      PAGE_E4       = READ_ONLY   DATA_FAR IBCC_FAR  0xE48000 TO 0xE4BFFF;
      PAGE_E5       = READ_ONLY   DATA_FAR IBCC_FAR  0xE58000 TO 0xE5BFFF;
      PAGE_E6       = READ_ONLY   DATA_FAR IBCC_FAR  0xE68000 TO 0xE6BFFF;
      PAGE_E7       = READ_ONLY   DATA_FAR IBCC_FAR  0xE78000 TO 0xE7BFFF;
      PAGE_E8       = READ_ONLY   DATA_FAR IBCC_FAR  0xE88000 TO 0xE8BFFF;
      PAGE_E9       = READ_ONLY   DATA_FAR IBCC_FAR  0xE98000 TO 0xE9BFFF;
      PAGE_EA       = READ_ONLY   DATA_FAR IBCC_FAR  0xEA8000 TO 0xEABFFF;
      PAGE_EB       = READ_ONLY   DATA_FAR IBCC_FAR  0xEB8000 TO 0xEBBFFF;
      PAGE_EC       = READ_ONLY   DATA_FAR IBCC_FAR  0xEC8000 TO 0xECBFFF;
      PAGE_ED       = READ_ONLY   DATA_FAR IBCC_FAR  0xED8000 TO 0xEDBFFF;
      PAGE_EE       = READ_ONLY   DATA_FAR IBCC_FAR  0xEE8000 TO 0xEEBFFF;
      PAGE_EF       = READ_ONLY   DATA_FAR IBCC_FAR  0xEF8000 TO 0xEFBFFF;
      PAGE_F0       = READ_ONLY   DATA_FAR IBCC_FAR  0xF08000 TO 0xF0BFFF;
      PAGE_F1       = READ_ONLY   DATA_FAR IBCC_FAR  0xF18000 TO 0xF1BFFF;
      PAGE_F2       = READ_ONLY   DATA_FAR IBCC_FAR  0xF28000 TO 0xF2BFFF;
      PAGE_F3       = READ_ONLY   DATA_FAR IBCC_FAR  0xF38000 TO 0xF3BFFF;
      PAGE_F4       = READ_ONLY   DATA_FAR IBCC_FAR  0xF48000 TO 0xF4BFFF;
      PAGE_F5       = READ_ONLY   DATA_FAR IBCC_FAR  0xF58000 TO 0xF5BFFF;
      PAGE_F6       = READ_ONLY   DATA_FAR IBCC_FAR  0xF68000 TO 0xF6BFFF;
      PAGE_F7       = READ_ONLY   DATA_FAR IBCC_FAR  0xF78000 TO 0xF7BFFF;
      PAGE_F8       = READ_ONLY   DATA_FAR IBCC_FAR  0xF88000 TO 0xF8BFFF;
      PAGE_F9       = READ_ONLY   DATA_FAR IBCC_FAR  0xF98000 TO 0xF9BFFF;
      PAGE_FA       = READ_ONLY   DATA_FAR IBCC_FAR  0xFA8000 TO 0xFABFFF;
      PAGE_FB       = READ_ONLY   DATA_FAR IBCC_FAR  0xFB8000 TO 0xFBBFFF;
      PAGE_FC       = READ_ONLY   DATA_FAR IBCC_FAR  0xFC8000 TO 0xFCBFFF;
/*    PAGE_FD       = READ_ONLY                      0xFD8000 TO 0xFDBFFF; intentionally not defined: equivalent to ROM_4000 */
      PAGE_FE       = READ_ONLY   DATA_FAR IBCC_FAR  0xFE8000 TO 0xFEBFFF;
/*    PAGE_FF       = READ_ONLY                      0xFF8000 TO 0xFFBFFF; intentionally not defined: equivalent to ROM_C000 */
END
PLACEMENT
    SOFTVECTABLE                 INTO SOFTVTABLE;
    VECTABLE                     INTO VECTOR_TABLE;
    _PRESTART,                   /* Used in HIWARE format: jump to _Startup at the code start */
    STARTUP,
    STARTUP_DATA,                /* startup data structures */
    ROM_VAR,                     /* constant variables */
    STRINGS,                     /* string literals */
    VIRTUAL_TABLE_SEGMENT,       /* C++ virtual table segment */
    NON_BANKED,                  /* runtime routines which must not be banked */
    INTERRUPT_ROUTINES,          /* Interrupt service routines */
    COPY                         /* copy down information: how to initialize variables */
                                 /* in case you want to use ROM_4000 here as well, make sure
                                    that all files (incl. library files) are compiled with the
                                    option: -OnB=b */
                                 INTO  ROM_4000;
    DEFAULT_ROM                  INTO  PAGE_C0,PAGE_C1,PAGE_C2,PAGE_C3,PAGE_C4,PAGE_C5,PAGE_C6,PAGE_C7,
                                       PAGE_C8,PAGE_C9,PAGE_CA,PAGE_CB,PAGE_CC,PAGE_CD,PAGE_CE,PAGE_CF,
                                       PAGE_D0,PAGE_D1,PAGE_D2,PAGE_D3,PAGE_D4,PAGE_D5,PAGE_D6,PAGE_D7,
                                       PAGE_D8,PAGE_D9,PAGE_DA,PAGE_DB,PAGE_DC,PAGE_DD,PAGE_DE,PAGE_DF,
                                       PAGE_E0,PAGE_E1,PAGE_E2,PAGE_E3,PAGE_E4,PAGE_E5,PAGE_E6,PAGE_E7,
                                       PAGE_E8,PAGE_E9,PAGE_EA,PAGE_EB,PAGE_EC,PAGE_ED,PAGE_EE,PAGE_EF,
                                       PAGE_F0,PAGE_F1,PAGE_F2,PAGE_F3,PAGE_F4,PAGE_F5,PAGE_F6,PAGE_F7,
                                       PAGE_F8,PAGE_F9,PAGE_FA,PAGE_FB,PAGE_FC,PAGE_FE;
    DEFAULT_RAM                  INTO  RAM;
END
STACKSIZE 0x200
If change the "DEFAULT_ROM" The error occurs in the PAGE_FE.
      DEFAULT_ROM       INTO           PAGE_FE,          PAGE_FC, PAGE_FB, PAGE_FA, PAGE_F9, PAGE_F8,
                              PAGE_F7, PAGE_F6, PAGE_F5, PAGE_F4, PAGE_F3, PAGE_F2, PAGE_F1, PAGE_F0,
                              PAGE_EF, PAGE_EE, PAGE_ED, PAGE_EC, PAGE_EB, PAGE_EA, PAGE_E9, PAGE_E8,
                              PAGE_E7, PAGE_E6, PAGE_E5, PAGE_E4, PAGE_E3, PAGE_E2, PAGE_E1, PAGE_E0,
                              PAGE_DF, PAGE_DE, PAGE_DD, PAGE_DC, PAGE_DB, PAGE_DA, PAGE_D9, PAGE_D8,
                              PAGE_D7, PAGE_D6, PAGE_D5, PAGE_D4, PAGE_D3, PAGE_D2, PAGE_D1, PAGE_D0,
                              PAGE_CF, PAGE_CE, PAGE_CD, PAGE_CC, PAGE_CB, PAGE_CA, PAGE_C9, PAGE_C8,
                              PAGE_C7, PAGE_C6, PAGE_C5, PAGE_C4, PAGE_C3, PAGE_C2, PAGE_C1, PAGE_C0;
if add -OnB=b
WARNING Warning: Ignoring old option content 'nB=b' because of second one '../CANTEST_S20150729.elf
used codewarrior had same error
trytohelp
Unfortunately this is how the tool is working.
I think your application contains a big function requiring more than 1 page of memory.
Unfortunately the linker can not split a function in 2 pages.
Attached you will find an example based on XEP100 using simulator.
This example shows you how the linker allocates the bank memory.
A function or a table for variable must no be higher than 1 page.
Else the linker will generate an error as:
    Link Error  : L1102: Out of allocation space in segment PAGE_FE at address 0xFE8017
The example shows you the behavior.
The function_test_1 contains 1 instruction nop which when it is valid generate the error.
    See line 16431 in main.c file
The function_test_2 and function_test_3 contains more code than function_test_1.
As you can see in the map file the linker allocates the memory correctly -> using different pages.
function_test_3                 FA80001B272  PAGE_FA_740
Init                             FA801B29412  PAGE_FA_740
function_test_2                 FB80004000 16384 2 PAGE_FB_739
function_test_1                 FC8000400016384 2 PAGE_FC_738
main                             FE800017232  .text
However the linker can not split a function in 2 memory pages.
This must be managed by the user.
Pascal
Freescale Technical Support
trytohelp
Pascal
