hi
i have a mpc8568 eval board.
i need to know my board's ip but i didn't find it in any doc . what should i do?
(i couldn't boot linux on it,so i can't use linux to find it )
hossein
The IP address to the board is assigned by Linux. If you do not have Linux on your board than you can not connect to this board externally.
Do you have working U-boot on your board? If yes than you can connect the to board to the PC via serial console cable and burn Linux image using U-boot commands
If you do not have working U-boot, than you need debug probe to flash the onboard flash.
