Not able to start hotspot with Kitakat 4.4.3
Question asked by mutyalarao neelapala on Jul 28, 2015
Hi all,
          I am trying to bring up hotspot with BSD interface. I compiled android supplicant with BSD compatible but when i give a click on hotspot it is showing turning ON hotspot.When I am seeing the hostap.conf file after flashing the image,it is showing driver=nl80211 instead of bsd. I am sharing my logcat details below.Can anybody please help me in getting out of this.
Thank you,
Mutyala Rao.
logcat
--------- beginning of /dev/log/main
I/installd(  124): installd firing up
I/DEBUG   (  119): debuggerd: May 13 2015 17:06:11
I/Netd    (  118): Netd 1.0 starting
W/InterfaceController(  118): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
E/DirectVolume(  117): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/extsd
E/DirectVolume(  117): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/udisk
--------- beginning of /dev/log/system
I/Vold    (  117): Vold 2.1 (the revenge) firing up
D/Vold    (  117): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    (  117): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
I/SurfaceFlinger(  120): SurfaceFlinger is starting
I/SurfaceFlinger(  120): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL  (  120): loaded /system/lib/egl/libGLES_android.so
I/imx6.gralloc(  120): fb_device_open dispid:0, fb:0
I/imx6.gralloc(  120): 16bpp setting of Framebuffer with RGB565 format!
W/imx6.gralloc(  120): using (fd=18)
W/imx6.gralloc(  120): id           = mxs-lcdif
W/imx6.gralloc(  120): xres         = 800 px
W/imx6.gralloc(  120): yres         = 480 px
W/imx6.gralloc(  120): xres_virtual = 800 px
W/imx6.gralloc(  120): yres_virtual = 1440 px
W/imx6.gralloc(  120): bpp          = 16
W/imx6.gralloc(  120): r            = 11:5
W/imx6.gralloc(  120): g            =  5:6
W/imx6.gralloc(  120): b            =  0:5
W/imx6.gralloc(  120): width        = 127 mm (160.000000 dpi)
W/imx6.gralloc(  120): height       = 76 mm (160.421051 dpi)
W/imx6.gralloc(  120): refresh rate = 60.26 Hz
I/FslHwcomposer(  120): using fsl hwc!!!
I/FslHwcomposer(  120): int hwc_device_open(const hw_module_t*, const char*, hw_device_t**),553
I/FslHwcomposer(  120): open /sys/class/graphics/fb0/fsl_disp_dev_property failed
W/FslHwcomposer(  120): open /sys/class/graphics/fb1 failed
W/FslHwcomposer(  120): open /sys/class/graphics/fb2 failed
W/FslHwcomposer(  120): open /sys/class/graphics/fb3 failed
W/FslHwcomposer(  120): open /sys/class/graphics/fb4 failed
W/FslHwcomposer(  120): open /sys/class/graphics/fb5 failed
I/FslHwcomposer(  120): hwcomposer: open framebuffer fb0
I/imx6.gralloc(  120): display already initialized...
I/FslHwcomposer(  120): int hwc_device_open(const hw_module_t*, const char*, hw_device_t**),426
I/SurfaceFlinger(  120): Using composer version 1.3
W/SurfaceFlinger(  120): no suitable EGLConfig found, trying a simpler query
W/SurfaceFlinger(  120): EGL_SLOW_CONFIG selected!
I/SurfaceFlinger(  120): EGL informations:
I/SurfaceFlinger(  120): vendor    : Android
I/SurfaceFlinger(  120): version   : 1.4 Android META-EGL
I/SurfaceFlinger(  120): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_image_base EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer
I/SurfaceFlinger(  120): Client API: OpenGL_ES
I/SurfaceFlinger(  120): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger(  120): OpenGL ES informations:
I/SurfaceFlinger(  120): renderer  : Android PixelFlinger 1.4
I/SurfaceFlinger(  120): version   : OpenGL ES-CM 1.0
I/SurfaceFlinger(  120): extensions: GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image GL_OES_EGL_sync GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger(  120): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger(  120): GL_MAX_VIEWPORT_DIMS = 4096
E/cutils-trace(  120): Error opening trace file: Permission denied (13)
D/SurfaceFlinger(  120): Screen acquired, type=0 flinger=0x785a9450
I/FslHwcomposer(  120): prepare: targetHandle is null
D/libEGL  (  166): loaded /system/lib/egl/libGLES_android.so
E/cutils-trace(  166): Error opening trace file: Permission denied (13)
I/mediaserver(  123): ServiceManager: 0x77cdf470
I/AudioFlinger(  123): Using default 3000 mSec as standby time.
I/CameraService(  123): CameraService started (pid=123)
I/CameraService(  123): Loaded "Freescale CameraHal Module" camera module
I/FslCameraHAL(  123): Face Back Camera is csi, orient is 0
I/FslCameraHAL(  123): Face Front Camera is uvc, orient is 0
I/FslCameraHAL(  123): Camera ID 0: name csi, Facing 0, orientation 0, dev path
I/FslCameraHAL(  123): Camera ID 0: name uvc, Facing 1, orientation 0, dev path
I/AudioPolicyManagerBase(  123): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary(  123): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary(  123): out rate 44100
W/audio_hw_primary(  123): in rate 44100, channels 1 format 0
W/audio_hw_primary(  123): card 1, id imxspdif ,driver imx-spdif, name imx-spdif
W/audio_hw_primary(  123): in rate 0, channels 0 format 0
I/AudioFlinger(  123): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary(  123): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary(  123): opened out stream...2010032040, type 1
I/AudioFlinger(  123): HAL output buffer size 192 frames, normal mix buffer size 768 frames
I/AudioMixer(  123): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe(  123): Failed to fetch local time frequency when constructing a MonoPipe (res = -32).  getNextWriteTimestamp calls will be non-functional
I/ARMAssembler(  166): generated scanline__00000077:03010102_00000A01_00000000 [  9 ipp] (30 ins) at [0x6e1811f0:0x6e181268] in 110959 ns
I/ARMAssembler(  166): generated scanline__00000077:03545402_00000A01_00000000 [ 31 ipp] (52 ins) at [0x6e181270:0x6e181340] in 62791 ns
D/AndroidRuntime(  121):
D/AndroidRuntime(  121): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(  121): CheckJNI is OFF
I/AndroidRuntime(  121): JNI options: '-Xjniopts:warnonly'
D/dalvikvm(  121): Trying to load lib libjavacore.so 0x0
D/dalvikvm(  121): Added shared lib libjavacore.so 0x0
D/dalvikvm(  121): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(  121): Added shared lib libnativehelper.so 0x0
D/dalvikvm(  121): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm(  121): Note: class Landroid/app/ActivityManagerNative; has 179 unimplemented (abstract) methods
E/memtrack(  121): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug(  121): failed to load memtrack module: -2
I/SamplingProfilerIntegration(  121): Profiling disabled.
I/Zygote  (  121): Preloading classes...
E/cutils-trace(  121): Error opening trace file: Permission denied (13)
D/dalvikvm(  121): GC_EXPLICIT freed 39K, 8% free 520K/564K, paused 0ms+0ms, total 4ms
D/dalvikvm(  121): GC_EXPLICIT freed 3K, 4% free 596K/616K, paused 0ms+0ms, total 6ms
D/dalvikvm(  121): GC_EXPLICIT freed 16K, 3% free 640K/660K, paused 0ms+1ms, total 23ms
V/NatController(  118): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController(  118): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController(  118): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController(  118): runCmd(/system/bin/ip rule flush) res=0
V/NatController(  118): runCmd(/system/bin/ip -6 rule flush) res=0
D/dalvikvm(  121): GC_EXPLICIT freed 20K, 4% free 674K/696K, paused 0ms+1ms, total 20ms
V/NatController(  118): runCmd(/system/bin/ip rule add from all lookup default prio 32767) res=0
V/NatController(  118): runCmd(/system/bin/ip rule add from all lookup main prio 32766) res=0
V/NatController(  118): runCmd(/system/bin/ip -6 rule add from all lookup default prio 32767) res=0
V/NatController(  118): runCmd(/system/bin/ip -6 rule add from all lookup main prio 32766) res=0
V/NatController(  118): runCmd(/system/bin/ip route flush cache) res=0
V/NatController(  118): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=1
V/NatController(  118): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=1
D/dalvikvm(  121): GC_EXPLICIT freed 10K, 2% free 718K/732K, paused 0ms+1ms, total 7ms
V/NatController(  118): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
D/dalvikvm(  121): GC_EXPLICIT freed 27K, 4% free 747K/776K, paused 1ms+1ms, total 14ms
D/dalvikvm(  121): GC_EXPLICIT freed 35K, 5% free 816K/856K, paused 1ms+0ms, total 25ms
D/MDnsDS  (  118): MDnsSdListener::Hander starting up
D/MDnsDS  (  118): MDnsSdListener starting to monitor
D/MDnsDS  (  118): Going to poll with pollCount 1
D/dalvikvm(  121): GC_EXPLICIT freed 29K, 4% free 843K/876K, paused 0ms+0ms, total 4ms
D/TextLayoutCache(  121): Using debug level = 0 - Debug Enabled = 0
D/dalvikvm(  121): GC_EXPLICIT freed 19K, 3% free 884K/908K, paused 0ms+0ms, total 4ms
I/dalvikvm(  121): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(  121): register_android_mtp_MtpDevice
D/dalvikvm(  121): GC_EXPLICIT freed 19K, 3% free 920K/944K, paused 1ms+1ms, total 5ms
D/dalvikvm(  121): GC_EXPLICIT freed 21K, 3% free 956K/980K, paused 1ms+1ms, total 5ms
D/dalvikvm(  121): GC_EXPLICIT freed 14K, 2% free 994K/1012K, paused 0ms+0ms, total 5ms
D/dalvikvm(  121): GC_EXPLICIT freed 28K, 3% free 1020K/1052K, paused 1ms+0ms, total 5ms
D/dalvikvm(  121): GC_EXPLICIT freed 16K, 2% free 1075K/1096K, paused 0ms+1ms, total 5ms
E/EmojiFactory_jni(  121): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
D/dalvikvm(  121): GC_EXPLICIT freed 30K, 3% free 1391K/1424K, paused 1ms+1ms, total 9ms
D/dalvikvm(  121): GC_EXPLICIT freed 35K, 3% free 1415K/1452K, paused 1ms+1ms, total 9ms
D/dalvikvm(  121): GC_EXPLICIT freed 30K, 3% free 1440K/1476K, paused 1ms+1ms, total 9ms
D/dalvikvm(  121): GC_EXPLICIT freed 38K, 3% free 1457K/1496K, paused 1ms+0ms, total 9ms
I/LibraryLoader(  121): Loading: webviewchromium
I/LibraryLoader(  121): Time to load native libraries: 561 ms (timestamps 824-1385)
I/LibraryLoader(  121): Expected native library version number "",actual native library version number ""
D/dalvikvm(  121): GC_EXPLICIT freed 15K, 2% free 1496K/1516K, paused 1ms+1ms, total 9ms
D/dalvikvm(  121): GC_EXPLICIT freed 21K, 2% free 1528K/1552K, paused 1ms+1ms, total 14ms
D/dalvikvm(  121): GC_EXPLICIT freed 86K, 6% free 1579K/1668K, paused 1ms+1ms, total 10ms
D/dalvikvm(  121): GC_EXPLICIT freed 36K, 5% free 1597K/1668K, paused 1ms+1ms, total 10ms
D/dalvikvm(  121): GC_EXPLICIT freed 31K, 3% free 1623K/1668K, paused 1ms+1ms, total 12ms
D/dalvikvm(  121): GC_EXPLICIT freed 19K, 2% free 1685K/1708K, paused 1ms+2ms, total 11ms
D/dalvikvm(  121): GC_EXPLICIT freed 23K, 2% free 1716K/1744K, paused 2ms+2ms, total 18ms
D/dalvikvm(  121): GC_EXPLICIT freed 28K, 2% free 1743K/1776K, paused 1ms+1ms, total 11ms
D/dalvikvm(  121): GC_FOR_ALLOC freed 250K, 12% free 2003K/2256K, paused 18ms, total 18ms
D/dalvikvm(  121): GC_EXPLICIT freed 210K, 10% free 2124K/2340K, paused 1ms+1ms, total 14ms
D/dalvikvm(  121): GC_EXPLICIT freed 35K, 9% free 2143K/2340K, paused 2ms+2ms, total 15ms
D/dalvikvm(  121): GC_EXPLICIT freed 25K, 8% free 2176K/2348K, paused 1ms+1ms, total 15ms
W/Zygote  (  121): Class not found for preloading: java.lang.UnsafeByteSequence
D/dalvikvm(  121): GC_EXPLICIT freed 36K, 7% free 2196K/2348K, paused 1ms+1ms, total 14ms
D/dalvikvm(  121): GC_EXPLICIT freed 40K, 6% free 2212K/2348K, paused 1ms+2ms, total 20ms
D/dalvikvm(  121): GC_EXPLICIT freed 42K, 6% free 2225K/2348K, paused 1ms+2ms, total 16ms
I/System  (  121): Loaded time zone names for "" in 95ms (90ms in ICU)
I/System  (  121): Loaded time zone names for "en_US" in 58ms (53ms in ICU)
D/dalvikvm(  121): GC_EXPLICIT freed 193K, 9% free 2388K/2600K, paused 1ms+2ms, total 16ms
D/dalvikvm(  121): GC_EXPLICIT freed 14K, 6% free 2452K/2600K, paused 1ms+2ms, total 23ms
D/dalvikvm(  121): GC_EXPLICIT freed 30K, 5% free 2478K/2600K, paused 2ms+1ms, total 17ms
D/dalvikvm(  121): GC_EXPLICIT freed 34K, 4% free 2499K/2600K, paused 2ms+1ms, total 17ms
D/dalvikvm(  121): GC_EXPLICIT freed 32K, 4% free 2520K/2600K, paused 1ms+1ms, total 22ms
D/dalvikvm(  121): GC_EXPLICIT freed 29K, 3% free 2546K/2604K, paused 2ms+1ms, total 19ms
I/Zygote  (  121): ...preloaded 2777 classes in 4407ms.
D/dalvikvm(  121): GC_EXPLICIT freed 17K, 3% free 2548K/2604K, paused 2ms+2ms, total 17ms
I/Zygote  (  121): Preloading resources...
W/Resources(  121): Preloaded drawable resource #0x1080096 (android:drawable/toast_frame) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080105 (android:drawable/btn_check_on_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080104 (android:drawable/btn_check_on_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080102 (android:drawable/btn_check_on_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080101 (android:drawable/btn_check_on_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800ff (android:drawable/btn_check_on_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800fe (android:drawable/btn_check_on_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800fd (android:drawable/btn_check_on_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800fc (android:drawable/btn_check_on_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800fb (android:drawable/btn_check_on_disabled_focused_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 34K, 3% free 2566K/2628K, paused 1ms+2ms, total 16ms
W/Resources(  121): Preloaded drawable resource #0x10800fa (android:drawable/btn_check_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800f2 (android:drawable/btn_check_off_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800f1 (android:drawable/btn_check_off_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800ed (android:drawable/btn_check_off_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800ec (android:drawable/btn_check_off_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800ea (android:drawable/btn_check_off_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800e9 (android:drawable/btn_check_off_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800e8 (android:drawable/btn_check_off_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800e7 (android:drawable/btn_check_off_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800e6 (android:drawable/btn_check_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800e5 (android:drawable/btn_check_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800dc (android:drawable/btn_check_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 102K, 5% free 2568K/2684K, paused 2ms+1ms, total 19ms
W/Resources(  121): Preloaded drawable resource #0x10800db (android:drawable/btn_check_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 61K, 5% free 2565K/2684K, paused 1ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x1080195 (android:drawable/btn_radio_on_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080194 (android:drawable/btn_radio_on_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080192 (android:drawable/btn_radio_on_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080191 (android:drawable/btn_radio_on_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018f (android:drawable/btn_radio_on_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018e (android:drawable/btn_radio_on_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018d (android:drawable/btn_radio_on_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018c (android:drawable/btn_radio_on_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018b (android:drawable/btn_radio_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108018a (android:drawable/btn_radio_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080187 (android:drawable/btn_radio_off_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080186 (android:drawable/btn_radio_off_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080184 (android:drawable/btn_radio_off_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 51K, 5% free 2567K/2684K, paused 1ms+1ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x1080183 (android:drawable/btn_radio_off_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080181 (android:drawable/btn_radio_off_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080180 (android:drawable/btn_radio_off_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108017f (android:drawable/btn_radio_off_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108017e (android:drawable/btn_radio_off_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108017d (android:drawable/btn_radio_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108017c (android:drawable/btn_radio_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080128 (android:drawable/btn_default_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080127 (android:drawable/btn_default_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080124 (android:drawable/btn_default_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080123 (android:drawable/btn_default_normal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108011c (android:drawable/btn_default_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108011b (android:drawable/btn_default_focused_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 37K, 4% free 2581K/2684K, paused 1ms+2ms, total 16ms
W/Resources(  121): Preloaded drawable resource #0x1080119 (android:drawable/btn_default_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080118 (android:drawable/btn_default_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080116 (android:drawable/btn_default_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080115 (android:drawable/btn_default_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108011d (android:drawable/btn_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108011e (android:drawable/btn_default_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 44K, 3% free 2609K/2684K, paused 2ms+2ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x10801d1 (android:drawable/btn_star_off_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801db (android:drawable/btn_star_on_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d7 (android:drawable/btn_star_on_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801cd (android:drawable/btn_star_off_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801dd (android:drawable/btn_star_on_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d3 (android:drawable/btn_star_off_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d9 (android:drawable/btn_star_on_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801cf (android:drawable/btn_star_off_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d5 (android:drawable/btn_star_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801cb (android:drawable/btn_star_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801c8 (android:drawable/btn_star_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 133K, 6% free 2577K/2724K, paused 1ms+2ms, total 19ms
W/Resources(  121): Preloaded drawable resource #0x10801d0 (android:drawable/btn_star_off_normal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801da (android:drawable/btn_star_on_normal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d6 (android:drawable/btn_star_on_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801cc (android:drawable/btn_star_off_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801dc (android:drawable/btn_star_on_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d2 (android:drawable/btn_star_off_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d8 (android:drawable/btn_star_on_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ce (android:drawable/btn_star_off_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801d4 (android:drawable/btn_star_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ca (android:drawable/btn_star_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801c7 (android:drawable/btn_star_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 97K, 6% free 2578K/2724K, paused 1ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x10801f7 (android:drawable/btn_toggle_on_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f6 (android:drawable/btn_toggle_on_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f5 (android:drawable/btn_toggle_on_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f4 (android:drawable/btn_toggle_on_normal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f3 (android:drawable/btn_toggle_on_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f2 (android:drawable/btn_toggle_on_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f1 (android:drawable/btn_toggle_on_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801f0 (android:drawable/btn_toggle_on_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ef (android:drawable/btn_toggle_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ee (android:drawable/btn_toggle_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ec (android:drawable/btn_toggle_off_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801eb (android:drawable/btn_toggle_off_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801ea (android:drawable/btn_toggle_off_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e9 (android:drawable/btn_toggle_off_normal_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 26K, 5% free 2607K/2724K, paused 6ms+2ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x10801e8 (android:drawable/btn_toggle_off_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e7 (android:drawable/btn_toggle_off_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e6 (android:drawable/btn_toggle_off_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e5 (android:drawable/btn_toggle_off_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e4 (android:drawable/btn_toggle_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e3 (android:drawable/btn_toggle_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10801e1 (android:drawable/btn_toggle_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 63K, 4% free 2623K/2724K, paused 1ms+1ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x10801e0 (android:drawable/btn_toggle_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 69K, 5% free 2609K/2724K, paused 1ms+2ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x108064c (android:drawable/textfield_multiline_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080650 (android:drawable/textfield_multiline_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108064a (android:drawable/textfield_multiline_activated_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080652 (android:drawable/textfield_multiline_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108064e (android:drawable/textfield_multiline_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108063f (android:drawable/textfield_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080644 (android:drawable/textfield_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080637 (android:drawable/textfield_activated_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080647 (android:drawable/textfield_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080642 (android:drawable/textfield_disabled_focused_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080258 (android:drawable/edit_text_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 55K, 5% free 2610K/2724K, paused 1ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x108064b (android:drawable/textfield_multiline_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108064f (android:drawable/textfield_multiline_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080649 (android:drawable/textfield_multiline_activated_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080651 (android:drawable/textfield_multiline_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108064d (android:drawable/textfield_multiline_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108063e (android:drawable/textfield_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080643 (android:drawable/textfield_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080636 (android:drawable/textfield_activated_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080646 (android:drawable/textfield_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080641 (android:drawable/textfield_disabled_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080257 (android:drawable/edit_text_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 55K, 5% free 2611K/2724K, paused 1ms+6ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x1080633 (android:drawable/text_select_handle_left) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080635 (android:drawable/text_select_handle_right) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080630 (android:drawable/text_edit_paste_window) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108026d (android:drawable/expander_close_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108026e (android:drawable/expander_close_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080274 (android:drawable/expander_open_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080270 (android:drawable/expander_group_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080275 (android:drawable/expander_open_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080271 (android:drawable/expander_group_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108041d (android:drawable/list_selector_disabled_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803fe (android:drawable/list_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803fc (android:drawable/list_longpressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108041a (android:drawable/list_selector_background_transition_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803f7 (android:drawable/list_focused_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080421 (android:drawable/list_selector_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 75K, 5% free 2609K/2724K, paused 1ms+2ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x108041e (android:drawable/list_selector_disabled_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803ff (android:drawable/list_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803fd (android:drawable/list_longpressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108041b (android:drawable/list_selector_background_transition_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080422 (android:drawable/list_selector_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080401 (android:drawable/list_section_divider_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080400 (android:drawable/list_section_divider_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080432 (android:drawable/menu_hardkey_panel_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080433 (android:drawable/menu_hardkey_panel_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108043a (android:drawable/menu_submenu_background) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080431 (android:drawable/menu_dropdown_panel_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080430 (android:drawable/menu_dropdown_panel_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 49K, 4% free 2617K/2724K, paused 1ms+1ms, total 23ms
W/Resources(  121): Preloaded drawable resource #0x1080437 (android:drawable/menu_popup_panel_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080436 (android:drawable/menu_popup_panel_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080435 (android:drawable/menu_panel_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080434 (android:drawable/menu_panel_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108047c (android:drawable/overscroll_edge) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 57K, 5% free 2617K/2748K, paused 1ms+2ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x108047d (android:drawable/overscroll_glow) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 187K, 11% free 2586K/2904K, paused 1ms+1ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x1080545 (android:drawable/spinner_16_outer_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080544 (android:drawable/spinner_16_inner_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080549 (android:drawable/spinner_48_outer_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080548 (android:drawable/spinner_48_inner_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108054b (android:drawable/spinner_76_outer_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108054a (android:drawable/spinner_76_inner_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804c5 (android:drawable/progress_bg_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804c6 (android:drawable/progress_bg_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 47K, 11% free 2590K/2904K, paused 1ms+2ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x10804d2 (android:drawable/progress_secondary_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804d0 (android:drawable/progress_primary_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804c7 (android:drawable/progress_horizontal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804d3 (android:drawable/progress_secondary_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804d1 (android:drawable/progress_primary_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804c8 (android:drawable/progress_horizontal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804db (android:drawable/progressbar_indeterminate_holo1) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804dc (android:drawable/progressbar_indeterminate_holo2) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804dd (android:drawable/progressbar_indeterminate_holo3) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804de (android:drawable/progressbar_indeterminate_holo4) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804df (android:drawable/progressbar_indeterminate_holo5) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804e0 (android:drawable/progressbar_indeterminate_holo6) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804e1 (android:drawable/progressbar_indeterminate_holo7) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804e2 (android:drawable/progressbar_indeterminate_holo8) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804c9 (android:drawable/progress_indeterminate_horizontal_holo) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 198K, 11% free 2598K/2904K, paused 1ms+2ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x10804cb (android:drawable/progress_large_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10804ce (android:drawable/progress_medium_holo) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 55K, 11% free 2595K/2904K, paused 2ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x10804d5 (android:drawable/progress_small_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080535 (android:drawable/scrubber_track_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080534 (android:drawable/scrubber_secondary_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080531 (android:drawable/scrubber_primary_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080532 (android:drawable/scrubber_progress_horizontal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080536 (android:drawable/scrubber_track_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080533 (android:drawable/scrubber_progress_horizontal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080528 (android:drawable/scrollbar_handle_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080529 (android:drawable/scrollbar_handle_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 30K, 10% free 2632K/2904K, paused 2ms+1ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x1080208 (android:drawable/cab_background_bottom_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108020b (android:drawable/cab_background_top_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080209 (android:drawable/cab_background_bottom_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802bc (android:drawable/ic_cab_done_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108020a (android:drawable/cab_background_top_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802bd (android:drawable/ic_cab_done_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d0 (android:drawable/btn_cab_done_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d3 (android:drawable/btn_cab_done_focused_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 34K, 9% free 2651K/2904K, paused 1ms+2ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x10800d1 (android:drawable/btn_cab_done_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d6 (android:drawable/btn_cab_done_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d2 (android:drawable/btn_cab_done_focused_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d7 (android:drawable/btn_cab_done_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d5 (android:drawable/btn_cab_done_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800d4 (android:drawable/btn_cab_done_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108033e (android:drawable/ic_menu_copy_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108033f (android:drawable/ic_menu_copy_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080341 (android:drawable/ic_menu_cut_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080342 (android:drawable/ic_menu_cut_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080355 (android:drawable/ic_menu_moreoverflow_normal_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080353 (android:drawable/ic_menu_moreoverflow_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 55K, 9% free 2650K/2904K, paused 3ms+1ms, total 19ms
W/Resources(  121): Preloaded drawable resource #0x1080356 (android:drawable/ic_menu_moreoverflow_normal_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080354 (android:drawable/ic_menu_moreoverflow_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080359 (android:drawable/ic_menu_paste_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108035a (android:drawable/ic_menu_paste_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080360 (android:drawable/ic_menu_selectall_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108035f (android:drawable/ic_menu_selectall_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802c0 (android:drawable/ic_clear_disabled) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802c2 (android:drawable/ic_clear_normal) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802bf (android:drawable/ic_clear) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080392 (android:drawable/ic_search) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802dd (android:drawable/ic_go) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 53K, 9% free 2648K/2904K, paused 1ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x108039b (android:drawable/ic_voice_search) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080221 (android:drawable/dialog_bottom_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080222 (android:drawable/dialog_bottom_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080226 (android:drawable/dialog_full_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080227 (android:drawable/dialog_full_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108022f (android:drawable/dialog_middle_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080230 (android:drawable/dialog_middle_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080231 (android:drawable/dialog_top_holo_dark) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 17K, 8% free 2687K/2904K, paused 1ms+1ms, total 22ms
W/Resources(  121): Preloaded drawable resource #0x1080232 (android:drawable/dialog_top_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802d1 (android:drawable/ic_dialog_alert_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10802d2 (android:drawable/ic_dialog_alert_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803f4 (android:drawable/list_divider_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803f5 (android:drawable/list_divider_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800bd (android:drawable/ab_transparent_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800bb (android:drawable/ab_stacked_transparent_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800a1 (android:drawable/ab_bottom_transparent_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800b5 (android:drawable/ab_solid_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800b8 (android:drawable/ab_stacked_solid_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108009e (android:drawable/ab_bottom_solid_dark_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800be (android:drawable/ab_transparent_light_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800bc (android:drawable/ab_stacked_transparent_light_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800a2 (android:drawable/ab_bottom_transparent_light_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800b6 (android:drawable/ab_solid_light_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800ba (android:drawable/ab_stacked_solid_light_holo) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 67K, 8% free 2673K/2904K, paused 2ms+2ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x10800a0 (android:drawable/ab_bottom_solid_light_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10800b7 (android:drawable/ab_solid_shadow_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803b3 (android:drawable/item_background_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x10803b4 (android:drawable/item_background_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027c (android:drawable/fastscroll_thumb_pressed_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027a (android:drawable/fastscroll_thumb_default_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027b (android:drawable/fastscroll_thumb_holo) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 67K, 9% free 2666K/2904K, paused 1ms+2ms, total 24ms
W/Resources(  121): Preloaded drawable resource #0x1080281 (android:drawable/fastscroll_track_pressed_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027d (android:drawable/fastscroll_track_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027f (android:drawable/fastscroll_track_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080276 (android:drawable/fastscroll_label_left_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080278 (android:drawable/fastscroll_label_right_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080282 (android:drawable/fastscroll_track_pressed_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108027e (android:drawable/fastscroll_track_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080280 (android:drawable/fastscroll_track_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 41K, 8% free 2679K/2904K, paused 1ms+2ms, total 18ms
W/Resources(  121): Preloaded drawable resource #0x1080277 (android:drawable/fastscroll_label_left_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080279 (android:drawable/fastscroll_label_right_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108025b (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080662 (android:drawable/textfield_search_selected_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080656 (android:drawable/textfield_search_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080664 (android:drawable/textfield_searchview_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108065f (android:drawable/textfield_search_right_selected_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108065d (android:drawable/textfield_search_right_default_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080666 (android:drawable/textfield_searchview_right_holo_dark) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080663 (android:drawable/textfield_search_selected_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080657 (android:drawable/textfield_search_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080665 (android:drawable/textfield_searchview_holo_light) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 48K, 8% free 2684K/2904K, paused 2ms+2ms, total 17ms
W/Resources(  121): Preloaded drawable resource #0x1080660 (android:drawable/textfield_search_right_selected_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108065e (android:drawable/textfield_search_right_default_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080667 (android:drawable/textfield_searchview_right_holo_light) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108062b (android:drawable/tab_unselected_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080626 (android:drawable/tab_selected_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108062a (android:drawable/tab_unselected_focused_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080625 (android:drawable/tab_selected_focused_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108062c (android:drawable/tab_unselected_pressed_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x1080627 (android:drawable/tab_selected_pressed_holo) that varies with configuration!!
W/Resources(  121): Preloaded drawable resource #0x108061a (android:drawable/tab_indicator_holo) that varies with configuration!!
D/dalvikvm(  121): GC_EXPLICIT freed 67K, 8% free 2674K/2904K, paused 1ms+1ms, total 20ms
I/Zygote  (  121): ...preloaded 274 resources in 1219ms.
I/Zygote  (  121): ...preloaded 31 resources in 11ms.
D/dalvikvm(  121): GC_EXPLICIT freed 24K, 8% free 2687K/2904K, paused 1ms+1ms, total 17ms
D/dalvikvm(  121): GC_EXPLICIT freed 12K, 8% free 2675K/2904K, paused 1ms+1ms, total 17ms
D/dalvikvm(  121): GC_EXPLICIT freed <1K, 8% free 2675K/2904K, paused 1ms+2ms, total 22ms
I/dalvikvm(  121): System server process 406 has been created
I/Zygote  (  121): Accepting command socket connections
D/        (  406): Setting time of day to sec=86400
W/SystemServer(  406): System clock is before 1970; setting to 1970.
D/SensorService(  406): nuSensorService starting...
E/SensorService(  406): couldn't load sensors module (No such file or directory)
I/installd(  124): new connection
I/SystemServer(  406): Entered the Android system server!
I/SystemServer(  406): Waiting for installd to be ready.
I/Installer(  406): connecting...
E/SWITCHPROFILE(  406): setprop: sys.interactive = active
I/SystemServer(  406): Power Manager
I/SystemServer(  406): Activity Manager
I/ActivityManager(  406): Memory class: 64
W/BatteryStatsImpl(  406): Couldn't get kernel wake lock stats
D/dalvikvm(  406): GC_CONCURRENT freed 200K, 9% free 2936K/3196K, paused 2ms+8ms, total 36ms
I/IntentFirewall(  406): Read new rules (A:0 B:0 S:0)
I/SystemServer(  406): Display Manager
I/SystemServer(  406): Telephony Registry
I/DisplayManagerService(  406): Display device added: DisplayDeviceInfo{"Built-in Screen": 800 x 480, 60.000004 fps, density 120, 160.0 x 160.421 dpi, touch INTERNAL, rotation 0, type BUILT_IN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer(  406): Scheduling Policy
I/SystemServer(  406): Package Manager
D/dalvikvm(  406): GC_CONCURRENT freed 378K, 13% free 3042K/3488K, paused 3ms+1ms, total 29ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 4ms
D/SELinuxMMAC(  406): Couldn't find install policy /data/security/mac_permissions.xml
D/SELinuxMMAC(  406): Using install policy file /system/etc/security/mac_permissions.xml
D/dalvikvm(  406): GC_CONCURRENT freed 218K, 8% free 3216K/3492K, paused 2ms+19ms, total 53ms
I/PackageManager(  406): /system/priv-app/BackupRestoreConfirmation.apk changed; collecting certs
I/AudioFlinger(  123): Using module 1 has the primary audio interface
I/AudioFlinger(  123): AudioFlinger's thread 0x760dd008 ready to run
W/audio_hw_primary(  123): out_set_parameters routing=2, ret 1, out 2010032040
I/audio_a2dp_hw(  123): adev_open:  adev_open in A2dp_hw module
I/AudioFlinger(  123): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/r_submix(  123): adev_open(name=audio_hw_if)
I/r_submix(  123): adev_init_check()
I/AudioFlinger(  123): loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 4
I/AudioFlinger(  123): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 5
I/AudioPolicyService(  123): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/dalvikvm(  406): GC_CONCURRENT freed 246K, 9% free 3426K/3732K, paused 2ms+15ms, total 53ms
I/PackageManager(  406): /system/priv-app/CalendarProvider.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/Contacts.apk changed; collecting certs
W/PackageParser(  406): No actions in intent filter at /system/priv-app/Contacts.apk Binary XML file line #375
D/dalvikvm(  406): GC_CONCURRENT freed 326K, 10% free 3585K/3972K, paused 3ms+2ms, total 27ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 14ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 206K, 14% free 3575K/4116K, paused 21ms, total 22ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 30K, 13% free 3607K/4116K, paused 15ms, total 15ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 85K, 13% free 3616K/4116K, paused 15ms, total 15ms
D/dalvikvm(  406): GC_CONCURRENT freed 217K, 7% free 3899K/4176K, paused 2ms+2ms, total 37ms
D/dalvikvm(  406): GC_CONCURRENT freed 361K, 10% free 3951K/4372K, paused 2ms+254ms, total 277ms
I/PackageManager(  406): /system/priv-app/ContactsProvider.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/DefaultContainerService.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/Dialer.apk changed; collecting certs
W/PackageParser(  406): No actions in intent filter at /system/priv-app/Dialer.apk Binary XML file line #163
D/dalvikvm(  406): GC_CONCURRENT freed 257K, 8% free 4197K/4520K, paused 3ms+14ms, total 37ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 1ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 852K, 24% free 3660K/4764K, paused 18ms, total 18ms
D/dalvikvm(  406): GC_CONCURRENT freed 260K, 18% free 3912K/4764K, paused 3ms+8ms, total 40ms
D/dalvikvm(  406): GC_CONCURRENT freed 291K, 14% free 4132K/4764K, paused 2ms+2ms, total 41ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 9ms
I/PackageManager(  406): /system/priv-app/DownloadProvider.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/ExternalStorageProvider.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/FusedLocation.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/InputDevices.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 472K, 13% free 4170K/4764K, paused 3ms+12ms, total 42ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 2ms
W/ResourceType(  406): Failure getting entry for 0x7f050000 (t=4 e=0) in package 0 (error -75)
I/PackageManager(  406): /system/priv-app/Keyguard.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 1004K, 23% free 3677K/4764K, paused 3ms+2ms, total 26ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 17ms
I/PackageManager(  406): /system/priv-app/Launcher2.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 412K, 21% free 3775K/4764K, paused 2ms+9ms, total 43ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 18ms
D/dalvikvm(  406): GC_CONCURRENT freed 458K, 20% free 3827K/4764K, paused 3ms+8ms, total 37ms
I/PackageManager(  406): /system/priv-app/MediaProvider.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 377K, 18% free 3912K/4764K, paused 2ms+5ms, total 46ms
I/PackageManager(  406): /system/priv-app/Mms.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 633K, 21% free 3791K/4764K, paused 3ms+3ms, total 44ms
I/PackageManager(  406): /system/priv-app/MusicFX.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 367K, 18% free 3931K/4764K, paused 6ms+3ms, total 47ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 5ms
I/PackageManager(  406): /system/priv-app/OneTimeInitializer.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/ProxyHandler.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 372K, 16% free 4037K/4764K, paused 3ms+15ms, total 70ms
I/PackageManager(  406): /system/priv-app/Settings.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 639K, 19% free 3906K/4764K, paused 3ms+2ms, total 27ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 3.991MB for 129040-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 93K, 20% free 3938K/4892K, paused 17ms, total 17ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 3.968MB for 72376-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 22% free 3882K/4964K, paused 17ms, total 17ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 118K, 20% free 4011K/4964K, paused 22ms, total 23ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.033MB for 65908-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 22% free 3948K/5032K, paused 18ms, total 18ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 114K, 19% free 4076K/5032K, paused 17ms, total 18ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.096MB for 65908-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 22% free 4013K/5100K, paused 17ms, total 17ms
D/dalvikvm(  406): GC_CONCURRENT freed 157K, 15% free 4368K/5100K, paused 2ms+3ms, total 47ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 7ms
D/dalvikvm(  406): GC_CONCURRENT freed 304K, 11% free 4575K/5100K, paused 2ms+9ms, total 51ms
I/PackageManager(  406): /system/priv-app/SettingsProvider.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/SharedStorageBackup.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 485K, 11% free 4602K/5144K, paused 2ms+7ms, total 43ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 12ms
I/PackageManager(  406): /system/priv-app/Shell.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/SystemUI.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 1163K, 25% free 3898K/5144K, paused 2ms+1ms, total 32ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 25ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 3.920MB for 63504-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 87K, 26% free 3873K/5208K, paused 20ms, total 20ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 89K, 26% free 3899K/5208K, paused 17ms, total 17ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 30K, 25% free 3931K/5208K, paused 17ms, total 17ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 3.942MB for 52487-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 63K, 26% free 3919K/5260K, paused 22ms, total 22ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 52K, 25% free 3982K/5260K, paused 18ms, total 18ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 3.992MB for 52487-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 63K, 26% free 3970K/5312K, paused 18ms, total 18ms
D/dalvikvm(  406): GC_CONCURRENT freed 150K, 19% free 4303K/5312K, paused 2ms+2ms, total 34ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 6ms
D/dalvikvm(  406): GC_CONCURRENT freed 295K, 16% free 4501K/5312K, paused 3ms+14ms, total 58ms
I/PackageManager(  406): /system/priv-app/TeleService.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 398K, 14% free 4614K/5312K, paused 3ms+12ms, total 45ms
I/PackageManager(  406): /system/priv-app/VpnDialogs.apk changed; collecting certs
I/PackageManager(  406): /system/priv-app/WallpaperCropper.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 1038K, 24% free 4088K/5312K, paused 2ms+5ms, total 46ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 8ms
I/PackageManager(  406): /system/app/BasicDreams.apk changed; collecting certs
I/PackageManager(  406): /system/app/Bluetooth.apk changed; collecting certs
W/PackageParser(  406): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #211
D/dalvikvm(  406): GC_CONCURRENT freed 601K, 27% free 3884K/5312K, paused 2ms+4ms, total 35ms
I/PackageManager(  406): /system/app/Browser.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 345K, 27% free 3922K/5312K, paused 3ms+1ms, total 24ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 13ms
D/dalvikvm(  406): GC_CONCURRENT freed 214K, 23% free 4111K/5312K, paused 2ms+2ms, total 30ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 20ms
I/PackageManager(  406): /system/app/Calculator.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 371K, 20% free 4251K/5312K, paused 2ms+6ms, total 39ms
I/PackageManager(  406): /system/app/Calendar.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 596K, 23% free 4123K/5312K, paused 2ms+2ms, total 25ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 11ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.140MB for 63504-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 174K, 26% free 4011K/5376K, paused 25ms, total 25ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 85K, 26% free 4018K/5376K, paused 18ms, total 18ms
D/dalvikvm(  406): GC_CONCURRENT freed 211K, 21% free 4283K/5376K, paused 7ms+2ms, total 39ms
I/PackageManager(  406): /system/app/CertInstaller.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 456K, 20% free 4338K/5376K, paused 2ms+5ms, total 39ms
I/PackageManager(  406): /system/app/CubeLiveWallpapers.apk changed; collecting certs
I/PackageManager(  406): /system/app/DeskClock.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 772K, 26% free 4025K/5376K, paused 4ms+2ms, total 29ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 22ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 158K, 25% free 4038K/5376K, paused 19ms, total 19ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 115K, 25% free 4084K/5376K, paused 24ms, total 24ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 30K, 24% free 4116K/5376K, paused 19ms, total 19ms
D/dalvikvm(  406): GC_CONCURRENT freed 203K, 19% free 4404K/5376K, paused 2ms+3ms, total 43ms
D/dalvikvm(  406): GC_CONCURRENT freed 303K, 16% free 4557K/5376K, paused 2ms+8ms, total 47ms
I/PackageManager(  406): /system/app/DocumentsUI.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 368K, 13% free 4700K/5376K, paused 2ms+6ms, total 43ms
I/PackageManager(  406): /system/app/DownloadProviderUi.apk changed; collecting certs
I/PackageManager(  406): /system/app/Email.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 908K, 20% free 4303K/5376K, paused 2ms+4ms, total 49ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 15ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 377K, 24% free 4095K/5376K, paused 21ms, total 21ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.107MB for 57538-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 63K, 25% free 4088K/5436K, paused 24ms, total 24ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 56K, 24% free 4153K/5436K, paused 19ms, total 19ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.159MB for 52555-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 63K, 25% free 4141K/5488K, paused 19ms, total 19ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 52K, 24% free 4204K/5488K, paused 19ms, total 19ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.209MB for 52555-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 63K, 25% free 4193K/5540K, paused 27ms, total 27ms
D/dalvikvm(  406): GC_CONCURRENT freed 151K, 19% free 4527K/5540K, paused 3ms+3ms, total 43ms
D/dalvikvm(  406): GC_CONCURRENT freed 296K, 15% free 4736K/5540K, paused 2ms+9ms, total 58ms
I/PackageManager(  406): /system/app/Exchange2.apk changed; collecting certs
I/PackageManager(  406): /system/app/FSLOta.apk changed; collecting certs
I/PackageManager(  406): /system/app/Gallery.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 488K, 15% free 4757K/5540K, paused 3ms+12ms, total 36ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 27ms
I/PackageManager(  406): /system/app/HTMLViewer.apk changed; collecting certs
I/PackageManager(  406): /system/app/KeyChain.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 1109K, 25% free 4166K/5540K, paused 2ms+4ms, total 49ms
I/PackageManager(  406): /system/app/LatinIME.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 452K, 24% free 4220K/5540K, paused 2ms+3ms, total 37ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 173K, 23% free 4285K/5540K, paused 30ms, total 30ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.317MB for 82779-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 25% free 4239K/5624K, paused 27ms, total 27ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 118K, 23% free 4368K/5624K, paused 20ms, total 21ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.391MB for 75645-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 25% free 4315K/5700K, paused 26ms, total 26ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 114K, 23% free 4442K/5700K, paused 20ms, total 21ms
I/dalvikvm-heap(  406): Grow heap (frag case) to 4.463MB for 75645-byte allocation
D/dalvikvm(  406): GC_FOR_ALLOC freed 127K, 25% free 4389K/5776K, paused 20ms, total 20ms
D/dalvikvm(  406): GC_CONCURRENT freed 155K, 18% free 4745K/5776K, paused 3ms+3ms, total 52ms
D/dalvikvm(  406): GC_CONCURRENT freed 332K, 15% free 4929K/5776K, paused 3ms+3ms, total 55ms
I/PackageManager(  406): /system/app/LegacyCamera.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 408K, 12% free 5083K/5776K, paused 3ms+13ms, total 53ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 19ms
D/dalvikvm(  406): GC_FOR_ALLOC freed 1291K, 27% free 4220K/5776K, paused 25ms, total 25ms
D/dalvikvm(  406): GC_CONCURRENT freed 210K, 22% free 4521K/5776K, paused 2ms+3ms, total 42ms
I/PackageManager(  406): /system/app/LiveWallpapers.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 296K, 18% free 4737K/5776K, paused 3ms+7ms, total 55ms
I/PackageManager(  406): /system/app/LiveWallpapersPicker.apk changed; collecting certs
I/PackageManager(  406): /system/app/MagicSmokeWallpapers.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 433K, 17% free 4818K/5776K, paused 2ms+14ms, total 52ms
I/PackageManager(  406): /system/app/Music.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 1048K, 26% free 4304K/5776K, paused 2ms+3ms, total 48ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 16ms
I/PackageManager(  406): /system/app/PacProcessor.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 446K, 26% free 4329K/5776K, paused 2ms+8ms, total 48ms
I/PackageManager(  406): /system/app/PackageInstaller.apk changed; collecting certs
I/PackageManager(  406): /system/app/PicoTts.apk changed; collecting certs
I/PackageManager(  406): /system/app/PinyinIME.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 616K, 27% free 4225K/5776K, paused 2ms+3ms, total 32ms
I/PackageManager(  406): /system/app/PrintSpooler.apk changed; collecting certs
I/PackageManager(  406): /system/app/Provision.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 441K, 26% free 4296K/5776K, paused 3ms+3ms, total 49ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 24ms
I/PackageManager(  406): /system/app/QuickSearchBox.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 472K, 25% free 4336K/5776K, paused 2ms+3ms, total 52ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 10ms
I/PackageManager(  406): /system/app/SoundRecorder.apk changed; collecting certs
I/PackageManager(  406): /system/app/TelephonyProvider.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 414K, 24% free 4433K/5776K, paused 3ms+4ms, total 47ms
I/PackageManager(  406): /system/app/UserDictionaryProvider.apk changed; collecting certs
I/PackageManager(  406): /system/app/VideoEditor.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 632K, 26% free 4304K/5776K, paused 3ms+2ms, total 29ms
I/PackageManager(  406): /system/app/VisualizationWallpapers.apk changed; collecting certs
D/dalvikvm(  406): GC_CONCURRENT freed 399K, 24% free 4413K/5776K, paused 3ms+9ms, total 58ms
I/PackageManager(  406): /system/app/ethernet.apk changed; collecting certs
D/PackageManager(  406): No files in app dir /vendor/app
W/PackageManager(  406): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager(  406): Time to scan packages: 7.322 seconds
W/PackageManager(  406): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager(  406): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager(  406): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  406): Unknown permission com.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  406): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager(  406): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager(  406): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager(  406): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager(  406): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager(  406): Unknown permission android.permission.INSTALL_DRM in package com.android.mms
W/PackageManager(  406): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager(  406): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager(  406): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
D/dalvikvm(  406): GC_CONCURRENT freed 435K, 23% free 4479K/5776K, paused 2ms+5ms, total 67ms
D/dalvikvm(  406): GC_EXPLICIT freed 548K, 30% free 4075K/5776K, paused 2ms+3ms, total 37ms
I/SystemServer(  406): Entropy Mixer
I/EntropyMixer(  406): Writing entropy...
I/SystemServer(  406): User Service
I/SystemServer(  406): Account Manager
I/SystemServer(  406): Content Manager
I/SystemServer(  406): System Content Providers
I/SystemServer(  406): Lights Service
I/lights  (  406): max backlight file is /sys/class/backlight/pwm-backlight.0/max_brightness
I/lights  (  406): backlight brightness file is /sys/class/backlight/pwm-backlight.0/brightness
E/ConsumerIrService(  406): Can't open consumer IR HW Module, error: -2
I/SystemServer(  406): Battery Service
I/SystemServer(  406): Vibrator Service
I/SystemServer(  406): Consumer IR Service
I/libsuspend(  406): Selected early suspend
I/libsuspend(  406): Starting early suspend unblocker thread
I/SWITCHPROFILE(  406): Switchprofile thread received GOV_INTERACTIVE from Power HAL
D/PermissionCache(  120): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (602 us)
D/SurfaceFlinger(  120): Screen acquired, type=0 flinger=0x785a9450
D/SurfaceFlinger(  120):  screen was previously acquired
I/SystemServer(  406): Alarm Manager
I/SystemServer(  406): Init Watchdog
I/SystemServer(  406): Input Manager
I/InputManager(  406): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer(  406): Window Manager
I/WindowManager(  406): No existing display settings /data/system/display_settings.xml; starting empty
I/WindowManager(  406): No keyguard interface!
I/InputManager(  406): Starting input manager
I/SystemServer(  406): No Bluetooth Service (Bluetooth Hardware Not Present)
I/SystemServer(  406): Input Method Service
W/InputMethodManagerService(  406): Couldn't create dir.: /data/system/inputmethod
E/EventHub(  406): could not get driver version for /dev/input/mice, Not a typewriter
W/ResourceType(  406): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/SystemServer(  406): Accessibility Manager
D/EventHub(  406): No input device configuration file found for device 'WM8962 Beep Generator'.
D/dalvikvm(  406): GC_CONCURRENT freed 203K, 27% free 4271K/5776K, paused 2ms+7ms, total 71ms
I/ActivityManager(  406): Config changes=1df8 {1.0 ?mcc?mnc en_US ldltr sw640dp w1066dp h640dp 120dpi lrg long land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
I/ActivityManager(  406): Config changes=500 {1.0 ?mcc?mnc en_US ldltr sw640dp w1066dp h566dp 120dpi lrg land ?uimode ?night -touch -keyb/v/h -nav/h s.3}
I/SystemServer(  406): Mount Service
D/MountService(  406): got storage path: null description: Internal storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService(  406): addVolumeLocked() StorageVolume:
D/MountService(  406):     mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040663
D/MountService(  406):     mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService(  406):     mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService(  406):     mUserLabel=null mState=null
D/MountService(  406): got storage path: /storage/extsd description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  406):     mStorageId=0 mPath=/storage/extsd mDescriptionId=17040664 mPrimary=false
D/MountService(  406):     mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService(  406):     mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService(  406): got storage path: /storage/udisk description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  406):     mStorageId=0 mPath=/storage/udisk mDescriptionId=17040665 mPrimary=false
I/SystemServer(  406): LockSettingsService
I/SystemServer(  406): Device Policy
I/SystemServer(  406): Status Bar
I/SystemServer(  406): Clipboard Service
I/SystemServer(  406): NetworkManagement Service
I/SystemServer(  406): Text Service Manager Service
D/MountService(  406): volume state changed for /storage/extsd (unmounted -> removed)
D/MountService(  406): volume state changed for /storage/udisk (unmounted -> removed)
E/EventHub(  406): could not get driver version for /dev/input/mouse0, Not a typewriter
I/PackageManager(  406): No secure containers on sdcard
I/SystemServer(  406): NetworkStats Service
I/SystemServer(  406): NetworkPolicy Service
I/SystemServer(  406): Wi-Fi P2pService
D/EventHub(  406): No input device configuration file found for device 'PixArt USB Optical Mouse'.
I/EventHub(  406): New device: id=2, fd=102, path='/dev/input/event1', name='PixArt USB Optical Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=true
I/EventHub(  406): New device: id=3, fd=103, path='/dev/input/event0', name='20b8000.kpp', classes=0x1, configuration='/system/usr/idc/20b8000_kpp.idc', keyLayout='/system/usr/keylayout/20b8000_kpp.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=true, usingSuspendBlockIoctl=true, usingClockIoctl=true
I/InputReader(  406): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader(  406): Device added: id=0, name='20b8000.kpp', sources=0x00000101
I/InputReader(  406): Device added: id=2, name='PixArt USB Optical Mouse', sources=0x00002002
I/InputReader(  406): Reconfiguring input devices.  changes=0x00000004
D/WifiMonitor(  406): Creating WifiMonitor
D/WifiMonitor(  406): WifiMonitorSingleton gotten
D/WifiMonitor(  406): WifiMonitorSingleton created
D/WifiMonitor(  406): registerInterface(p2p0+android.net.wifi.p2p.WifiP2pService$P2pStateMachine@2c657e88)
I/SystemServer(  406): Wi-Fi Service
D/WifiService(  406): RPS ************* mInterface name iswlan0End here
E/WifiStateMachine(  406): RPS WiFi state machine starting with interface name as wlan0andwlan0
D/WifiMonitor(  406): registerInterface(wlan0+android.net.wifi.WifiStateMachine@2c66b688)
D/dalvikvm(  406): GC_CONCURRENT freed 259K, 23% free 4467K/5776K, paused 7ms+24ms, total 109ms
D/WifiStateMachine(  406): completeConstruction: E
D/WifiStateMachine(  406): completeConstruction: maxDepth=6
D/WifiStateMachine(  406): setupInitialStateStack: E mInitialState=InitialState
D/WifiStateMachine(  406): moveTempStackToStateStack: i=1,j=0
D/WifiStateMachine(  406): moveTempStackToStateStack: i=0,j=1
D/WifiStateMachine(  406): moveTempStackToStateStack: X mStateStackTop=1,startingIndex=0,Top=InitialState
D/WifiStateMachine(  406): handleMessage: E msg.what=-2
D/WifiStateMachine(  406): invokeEnterMethods: DefaultState
D/WifiStateMachine(  406): invokeEnterMethods: InitialState
E/WifiHW  (  406): Beginning to unload driver here!!
D/WifiHW  (  406): Unable to unload driver module "onebox_wlan_gpl": No such file or directory
E/WifiHW  (  406): ******** *****ko rmmod failed
D/WifiStateMachine(  406): completeConstruction: X
D/WifiController(  406): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false
I/SystemServer(  406): Connectivity Service
D/ConnectivityService(  406): ConnectivityService starting up
D/ConnectivityService(  406): wifiOnly=false
E/ConnectivityService(  406): Ignoring protectedNetwork 14
E/WifiApConfigStore(  406): Bad version on hotspot configuration file, set defaults
D/WifiStateMachine(  406): handleMessage: X
D/WifiStateMachine(  406): handleMessage: E msg.what=69632
D/WifiStateMachine(  406): processMsg: InitialState
D/WifiStateMachine(  406): processMsg: DefaultState
D/WifiStateMachine(  406): handleMessage: E msg.what=131154
D/WifiStateMachine(  406): handleMessage: E msg.what=131084
D/CommandListener(  118): Setting iface cfg
D/CommandListener(  118): Trying to bring up eth0
D/WifiStateMachine(  406): handleMessage: E msg.what=131085
D/WifiStateMachine(  406): handleMessage: E msg.what=131146
E/MobileDataStateTracker(  406): default: Ignoring feature request because could not acquire PhoneService
E/MobileDataStateTracker(  406): default: Could not enable APN type "default"
I/WifiService(  406): WifiService starting up with Wi-Fi disabled
I/SystemServer(  406): Network Service Discovery Service
D/NsdService(  406): Network service discovery enabled true
I/SystemServer(  406): UpdateLock Service
I/SystemServer(  406): Notification Manager
I/SystemServer(  406): Device Storage Monitor
I/SystemServer(  406): Location Manager
I/SystemServer(  406): Country Detector
I/SystemServer(  406): Search Service
I/SystemServer(  406): DropBox Service
I/SystemServer(  406): Wallpaper Service
I/SystemServer(  406): Audio Service
D/dalvikvm(  406): GC_CONCURRENT freed 374K, 21% free 4568K/5776K, paused 3ms+12ms, total 69ms
I/MediaFocusControl(  406):   Remote Control   registerMediaButtonIntent() for PendingIntent{2c5e5aa0: PendingIntentRecord{2c5e4700 android broadcastIntent}}
I/SystemServer(  406): Dock Observer
W/DockObserver(  406): This kernel does not have dock station support
I/SystemServer(  406): Wired Accessory Manager
W/WiredAccessoryManager(  406): This kernel does not have HDMI audio support
I/SystemServer(  406): USB Service
I/SystemServer(  406): Serial Service
I/SystemServer(  406): Twilight Service
I/SystemServer(  406): UI Mode Manager Service
I/SystemServer(  406): Backup Service
V/BackupManagerService(  406): Initializing package tracking
V/BackupManagerService(  406): No ancestral data
V/BackupManagerService(  406): addPackageParticipantsLocked: all
I/BackupManagerService(  406): Scheduling backup for new app com.android.calendar
D/BackupManagerService(  406): Now staging backup of com.android.calendar
I/BackupManagerService(  406): Scheduling backup for new app com.android.browser
D/BackupManagerService(  406): Now staging backup of com.android.browser
I/BackupManagerService(  406): Scheduling backup for new app com.android.providers.userdictionary
D/BackupManagerService(  406): Now staging backup of com.android.providers.userdictionary
I/BackupManagerService(  406): Scheduling backup for new app com.android.sharedstoragebackup
D/BackupManagerService(  406): Now staging backup of com.android.sharedstoragebackup
I/BackupManagerService(  406): Scheduling backup for new app android
D/BackupManagerService(  406): Now staging backup of android
I/BackupManagerService(  406): Scheduling backup for new app com.android.dialer
D/BackupManagerService(  406): Now staging backup of com.android.dialer
I/BackupManagerService(  406): Scheduling backup for new app com.android.providers.settings
D/BackupManagerService(  406): Now staging backup of com.android.providers.settings
V/BackupManagerService(  406): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService(  406): Found transports: 1
I/BackupManagerService(  406): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/BackupManagerService(  406): Found stale backup journal, scheduling
I/BackupManagerService(  406):   com.android.calendar
I/BackupManagerService(  406):   com.android.browser
I/BackupManagerService(  406):   com.android.providers.userdictionary
I/BackupManagerService(  406):   com.android.sharedstoragebackup
I/BackupManagerService(  406):   android
I/BackupManagerService(  406):   com.android.dialer
I/BackupManagerService(  406):   com.android.providers.settings
I/BackupManagerService(  406): Backup enabled => false
I/BackupManagerService(  406): Opting out of backup
I/SystemServer(  406): AppWidget Service
I/SystemServer(  406): Recognition Service
I/SystemServer(  406): DiskStats Service
I/SystemServer(  406): SamplingProfiler Service
I/WindowManager(  406): SAFE MODE not enabled
D/dalvikvm(  406): JIT started for system_server
I/SystemServer(  406): NetworkTimeUpdateService
I/SystemServer(  406): CommonTimeManagementService
I/SystemServer(  406): CertBlacklister
I/SystemServer(  406): Dreams Service
I/SystemServer(  406): Assets Atlas Service
I/SystemServer(  406): IdleMaintenanceService
I/SystemServer(  406): Print Service
I/SystemServer(  406): Media Router Service
D/Atlas   (  406): Loaded configuration: SliceMinArea (768x768) flags=0x2 count=24
D/libEGL  (  406): loaded /system/lib/egl/libGLES_android.so
W/AssetAtlasService(  406): Could not find EGL configuration
D/Atlas   (  406): Rendered atlas in 7.77ms (0.90+6.87ms)
I/Zygote  (  406): Process: zygote socket opened
V/KeyguardServiceDelegate(  406): *** Keyguard started
V/KeyguardServiceDelegate(  406): onSystemReady() called before keyguard service was ready
I/ActivityManager(  406): Start proc com.android.systemui for service com.android.keyguard/.KeyguardService: pid=457 uid=10007 gids={50007, 1028, 1015, 1035, 3002, 3001}
F/SystemServer(  406): BOOT FAILURE making Package Manager Service ready
F/SystemServer(  406): java.lang.SecurityException: Unable to find app for caller android.app.ActivityThread$ApplicationThread@2c699750 (pid=406) when registering receiver android.app.LoadedApk$ReceiverDispatcher$InnerReceiver@2c6a4000
F/SystemServer(  406):     at com.android.server.am.ActivityManagerService.registerReceiver(ActivityManagerService.java:13021)
F/SystemServer(  406):     at android.app.ContextImpl.registerReceiverInternal(ContextImpl.java:1450)
F/SystemServer(  406):     at android.app.ContextImpl.registerReceiverAsUser(ContextImpl.java:1425)
F/SystemServer(  406):     at com.android.internal.content.PackageMonitor.register(PackageMonitor.java:84)
F/SystemServer(  406):     at com.android.server.pm.UserManagerService.systemReady(UserManagerService.java:239)
F/SystemServer(  406):     at com.android.server.pm.PackageManagerService.systemReady(PackageManagerService.java:10476)
F/SystemServer(  406):     at com.android.server.ServerThread.initAndLoop(SystemServer.java:893)
F/SystemServer(  406):     at com.android.server.SystemServer.main(SystemServer.java:1179)
F/SystemServer(  406):     at java.lang.reflect.Method.invokeNative(Native Method)
F/SystemServer(  406):     at java.lang.reflect.Method.invoke(Method.java:515)
F/SystemServer(  406):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785)
F/SystemServer(  406):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601)
F/SystemServer(  406):     at dalvik.system.NativeStart.main(Native Method)
W/SystemServer(  406): ***********************************************
D/dalvikvm(  406): GC_CONCURRENT freed 262K, 17% free 4818K/5776K, paused 3ms+4ms, total 105ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 34ms
I/AppOps  (  406): Pruning old package media/1013: new uid=-1
I/ActivityManager(  406): System now ready
I/SystemServer(  406): Making services ready
D/NetworkManagementService(  406): enabling bandwidth control
W/MountService(  406): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
V/KeyguardService(  457): onCreate()
E/cutils-trace(  123): Error opening trace file: Permission denied (13)
D/SystemUIService(  457): loading: class com.android.systemui.recent.Recents
D/SystemUIService(  457): running: com.android.systemui.recent.Recents@2c50bf68
D/SystemUIService(  457): loading: class com.android.systemui.statusbar.SystemBars
D/SystemUIService(  457): running: com.android.systemui.statusbar.SystemBars@2c50c550
D/SystemUIService(  457): loading: class com.android.systemui.usb.StorageNotification
D/SystemUIService(  457): running: com.android.systemui.usb.StorageNotification@2c50e310
D/SystemUIService(  457): loading: class com.android.systemui.power.PowerUI
D/SystemUIService(  457): running: com.android.systemui.power.PowerUI@2c50fa70
D/SystemUIService(  457): loading: class com.android.systemui.media.RingtonePlayer
D/SystemUIService(  457): running: com.android.systemui.media.RingtonePlayer@2c510d38
D/SystemUIService(  457): loading: class com.android.systemui.settings.SettingsUI
D/SystemUIService(  457): running: com.android.systemui.settings.SettingsUI@2c512020
I/StatusBarManagerService(  406): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@2c6e00c8
D/PhoneStatusBar(  457): mSettingsPanelGravity = 8388661
E/NetdConnector(  406): NDC Command {5 bandwidth enable} took too long (635ms)
D/dalvikvm(  457): GC_FOR_ALLOC freed 142K, 7% free 2893K/3096K, paused 48ms, total 49ms
V/PhoneStatusBar/NavigationBarView(  457): touchEnabled:false
D/dalvikvm(  457): GC_CONCURRENT freed 33K, 4% free 3278K/3380K, paused 2ms+34ms, total 81ms
E/BluetoothAdapter(  457): Bluetooth binder is null
W/ContextImpl(  406): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1131 com.android.server.usb.UsbSettingsManager.deviceAttached:621 com.android.server.usb.UsbHostManager.usbDeviceAdded:156 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:38
I/ActivityManager(  406): Start proc android.process.media for broadcast com.android.providers.media/.MtpReceiver: pid=529 uid=10005 gids={50005, 1028, 1015, 1023, 1024, 2001, 3003, 3007}
I/ActivityManager(  406): Config changes=200 {1.0 ?mcc?mnc en_US ldltr sw640dp w1066dp h566dp 120dpi lrg land -touch -keyb/v/h -nav/h s.4}
W/RecognitionManagerService(  406): no available voice recognition services found for user 0
W/InputMethodManagerService(  406): Ignoring setImeWindowStatus of uid 1000 token: null
I/ActivityManager(  406): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=542 uid=10027 gids={50027, 1028, 1015}
V/InputMethodManagerService(  406): Adding window token: android.os.Binder@2c777eb0
W/GpsLocationProvider(  406): Could not open GPS configuration file /etc/gps.conf
W/LocationManagerService(  406): no network location provider found
E/LocationManagerService(  406): no geocoder provider found
E/FlpHardwareProvider(  406): Error hw_get_module 'flp': -2
E/LocationManagerService(  406): No FusedProvider found.
E/LocationManagerService(  406): no geofence provider found
I/CommonTimeManagementService(  406): No common time service detected on this platform.  Common time services will be unavailable.
I/InputReader(  406): Reconfiguring input devices.  changes=0x00000020
D/dalvikvm(  406): GC_CONCURRENT freed 364K, 14% free 4990K/5776K, paused 27ms+5ms, total 129ms
D/dalvikvm(  406): WAIT_FOR_CONCURRENT_GC blocked 21ms
I/ActivityManager(  406): Start proc com.android.phone for added application com.android.phone: pid=556 uid=1001 gids={41001, 3002, 3001, 3003, 1028, 1015}
I/InputReader(  406): Reconfiguring input devices.  changes=0x00000010
I/ActivityManager(  406): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
I/ActivityManager(  406): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=561 uid=10008 gids={50008}
I/Choreographer(  406): Skipped 100 frames!  The application may be doing too much work on its main thread.
V/KeyguardServiceDelegate(  406): *** Keyguard connected (yay!)
W/InputMethodManagerService(  406): Focus gain on non-focused client android.view.inputmethod.InputMethodManager$1@2c6f1380 (uid=1000 pid=406)
I/LatinIME(  542): Hardware accelerated drawing: true
I/MediaFocusControl(  406):   Remote Control   registerMediaButtonIntent() for PendingIntent{2c6913b8: PendingIntentRecord{2c5e4700 android broadcastIntent}}
D/PhoneStatusBar(  457): disable: < expand icons alerts ticker system_info back home recent clock search >
V/BackupManagerService(  406): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService(  406): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@2c620280
D/dalvikvm(  561): GC_CONCURRENT freed 189K, 8% free 2937K/3164K, paused 15ms+1ms, total 62ms
D/dalvikvm(  457): GC_CONCURRENT freed 130K, 5% free 3631K/3820K, paused 5ms+16ms, total 54ms
I/ActivityManager(  406): Start proc com.android.printspooler for service com.android.printspooler/.PrintSpoolerService: pid=592 uid=10037 gids={50037}
I/ActivityManager(  406): Start proc android.process.acore for content provider com.android.providers.contacts/.ContactsProvider2: pid=606 uid=10002 gids={50002, 3003, 1028, 1015}
D/PhoneStatusBar(  457): heads up is disabled
I/Choreographer(  457): Skipped 79 frames!  The application may be doing too much work on its main thread.
I/PrintSpoolerService(  592): No existing print spooler state.
W/InputAttributes(  542): No editor info for this field. Bug?
I/ResourceUtils(  542): Found default value: resource=keypress_vibration_durations build=[HARDWARE=freescale MODEL=EVK_MX6SL BRAND=Freescale MANUFACTURER=Freescale] default=-1
I/ResourceUtils(  542): Found default value: resource=keypress_volumes build=[HARDWARE=freescale MODEL=EVK_MX6SL BRAND=Freescale MANUFACTURER=Freescale] default=-1.0f
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = userunigram.en_US.dict ; version = ? ; date = ?
D/dalvikvm(  542): GC_CONCURRENT freed 225K, 9% free 2885K/3168K, paused 3ms+22ms, total 172ms
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = main:en ; version = 42 ; date = 1381226429
D/dalvikvm(  406): GC_CONCURRENT freed 316K, 12% free 5130K/5776K, paused 2ms+3ms, total 134ms
I/FusedLocation(  406): engine started (com.android.location.fused)
E/BluetoothAdapter(  556): Bluetooth binder is null
D/dalvikvm(  606): GC_CONCURRENT freed 261K, 10% free 2931K/3248K, paused 9ms+2ms, total 105ms
D/dalvikvm(  606): WAIT_FOR_CONCURRENT_GC blocked 59ms
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = UserHistoryDictionary.en_US.dic ; version = ? ; date = 1437567121
D/dalvikvm(  561): GC_CONCURRENT freed 170K, 7% free 3165K/3392K, paused 4ms+58ms, total 132ms
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = personalization.en_US.dict ; version = ? ; date = 86434
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = PersonalizationPredictionDictio ; version = ? ; date = 86434
D/dalvikvm(  556): GC_CONCURRENT freed 168K, 8% free 2938K/3164K, paused 6ms+2ms, total 110ms
D/CallNotifier(  556): CallNotifier: mSignalInfoToneGenerator created when toneplay
D/MobileDataStateTracker(  406): fota: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=fota
D/MobileDataStateTracker(  406): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): supl: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=supl
D/MobileDataStateTracker(  406): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): hipri: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=hipri
D/MobileDataStateTracker(  406): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): ims: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=ims
D/dalvikvm(  606): WAIT_FOR_CONCURRENT_GC blocked 431ms
D/MobileDataStateTracker(  406): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): default: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=default
D/MobileDataStateTracker(  406): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): mms: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=mms
D/MobileDataStateTracker(  406): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): cbs: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=cbs
D/MobileDataStateTracker(  406): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker(  406): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker(  406): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
I/ActivityManager(  406): Displayed com.android.launcher/com.android.launcher2.Launcher: +2s217ms
D/MobileDataStateTracker(  406): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  406): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/TelephonyDebugService(  556): TelephonyDebugService()
D/MobileDataStateTracker(  406): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  406): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  406): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker(  406): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/PhoneStatusBar(  457): disable: < expand icons alerts ticker system_info back home RECENT* clock SEARCH* >
W/CallNotifier(  556): Got onMwiChanged() on non-voice-capable device! Ignoring...
V/KeyguardHostView(  457): Initial transport state: 1, pbstate=0
D/dalvikvm(  561): GC_CONCURRENT freed 72K, 5% free 3488K/3648K, paused 6ms+2ms, total 50ms
D/dalvikvm(  561): WAIT_FOR_CONCURRENT_GC blocked 35ms
D/dalvikvm(  457): GC_CONCURRENT freed 177K, 6% free 3955K/4192K, paused 4ms+2ms, total 49ms
I/Choreographer(  457): Skipped 119 frames!  The application may be doing too much work on its main thread.
V/KeyguardHostView(  457): music state changed: 0
D/dalvikvm(  457): GC_CONCURRENT freed 82K, 4% free 4331K/4472K, paused 6ms+17ms, total 102ms
D/dalvikvm(  457): GC_FOR_ALLOC freed 52K, 4% free 4324K/4472K, paused 27ms, total 28ms
I/dalvikvm-heap(  457): Grow heap (frag case) to 12.088MB for 8192016-byte allocation
D/dalvikvm(  457): GC_CONCURRENT freed 1K, 2% free 12323K/12476K, paused 5ms+2ms, total 39ms
D/dalvikvm(  457): GC_FOR_ALLOC freed 8001K, 4% free 4323K/4472K, paused 25ms, total 25ms
I/dalvikvm-heap(  457): Grow heap (frag case) to 12.087MB for 8192016-byte allocation
D/dalvikvm(  457): GC_CONCURRENT freed <1K, 2% free 12323K/12476K, paused 7ms+2ms, total 50ms
D/libEGL  (  457): loaded /system/lib/egl/libGLES_android.so
V/KeyguardServiceDelegate(  406): **** SHOWN CALLED ****
I/Choreographer(  457): Skipped 36 frames!  The application may be doing too much work on its main thread.
W/View    (  457): requestLayout() improperly called by android.widget.TextClock{2c5ed648 V.ED.... ......ID 29,0-280,141 #7f0a0047 app:id/clock_view} during layout: running second layout pass
W/View    (  457): requestLayout() improperly called by android.widget.TextClock{2c6869f0 V.ED.... ......ID 118,0-192,17 #7f0a004c app:id/date_view} during layout: running second layout pass
I/SurfaceFlinger(  120): Boot is finished (24769 ms)
D/PhoneStatusBar(  457): disable: < expand icons alerts ticker system_info BACK* HOME* RECENT CLOCK* SEARCH >
I/ActivityManager(  406): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=649 uid=1000 gids={41000, 3003, 1028, 1015, 3002, 3001}
D/MtpService(  529): updating state; isCurrentUser=true, mMtpLocked=false
D/MtpService(  529): addStorageLocked 65537 /storage/emulated/0
D/MtpService(  529): starting MTP server in MTP mode
D/dalvikvm(  406): GC_CONCURRENT freed 377K, 10% free 5243K/5776K, paused 2ms+9ms, total 43ms
E/BluetoothAdapter(  649): Bluetooth binder is null
I/ActivityManager(  406): Start proc com.android.music for broadcast com.android.music/.MediaButtonIntentReceiver: pid=669 uid=10032 gids={50032, 3003, 1028, 1015}
D/dalvikvm(  121): GC_EXPLICIT freed 38K, 4% free 2687K/2784K, paused 1ms+9ms, total 35ms
I/dalvikvm(  669): Enabling JNI app bug workarounds for target SDK version 9...
D/dalvikvm(  121): GC_EXPLICIT freed <1K, 4% free 2687K/2784K, paused 1ms+8ms, total 34ms
D/dalvikvm(  121): GC_EXPLICIT freed <1K, 4% free 2687K/2784K, paused 1ms+10ms, total 34ms
D/WifiStateMachine(  406): handleMessage: E msg.what=131206
E/BluetoothAdapter(  406): Bluetooth binder is null
V/WiredAccessoryManager(  406): init()
W/WiredAccessoryManager(  406): /sys/class/switch/usb_audio/state not found while attempting to determine initial switch state
I/PowerManagerService(  406): Boot animation finished.
I/RecoverySystem(  406): No recovery log file
I/ActivityManager(  406): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=690 uid=10001 gids={50001, 3003, 1028, 1015}
I/BootReceiver(  406): Copying audit failures to DropBox
I/BootReceiver(  406): Checking for fsck errors
I/MediaFocusControl(  406):   Remote Control   registerMediaButtonIntent() for PendingIntent{2c596278: PendingIntentRecord{2c5f1ac0 com.android.music broadcastIntent}}
V/KeyguardHostView(  457): hide transport, gen:2
V/KeyguardHostView(  457): update widget: transport state changed
V/KeyguardHostView(  457): hide transport, gen:3
D/dalvikvm(  561): GC_CONCURRENT freed 125K, 5% free 3754K/3944K, paused 2ms+2ms, total 22ms
I/CalendarProvider2(  690): Created com.android.providers.calendar.CalendarAlarmManager@2c50da18(com.android.providers.calendar.CalendarProvider2@2c5056e8)
I/ActivityManager(  406): Delay finish: com.android.providers.media/.MediaScannerReceiver
I/ActivityManager(  406): Delaying start of: ServiceRecord{2c789c80 u0 com.android.providers.calendar/.EmptyService}
D/dalvikvm(  561): GC_FOR_ALLOC freed 47K, 5% free 3767K/3956K, paused 15ms, total 23ms
I/dalvikvm-heap(  561): Grow heap (frag case) to 4.963MB for 1290512-byte allocation
D/dalvikvm(  561): GC_CONCURRENT freed 1K, 4% free 5026K/5220K, paused 2ms+2ms, total 20ms
D/dalvikvm(  529): GC_CONCURRENT freed 199K, 9% free 2865K/3124K, paused 2ms+3ms, total 35ms
I/ContactLocale(  606): AddressBook Labels [en_US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, ÃŽÂ’, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, ÃŽ ÃŽÂœ, Ν, Ξ, Ο, ÃŽÂ , Ρ, Σ, Τ, ÃŽÂ¥, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Е, Є, Ж, З, И, І, Ї, Й, К, Ð М, Н, О, П, Р, С, Т, У, Ф, Ð¥, Ц, Ч, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, × ל, מ, × , ס, ×¢, פ, צ, ק, ר, ש, ת, , ا, ب, ت, Ø«, ج, ØÂ, Ø®, د, Ø°, ر, ز, س, Ø´, ص, ض, Ø·, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , à ¸, à ¸‚, à ¸ƒ, à ¸„, à ¸…, à ¸†, à ¸‡, à ¸ˆ, à ¸‰, à ¸Š, à ¸‹, à ¸Œ, à ¸, à ¸Ž, à ¸, à ¸, à ¸‘, à ¸’, à ¸“, à ¸”, à ¸•, à ¸–, à ¸—, à ¸˜, à ¸™, à ¸š, à ¸ à ¸œ, à ¸, à ¸ž, à ¸Ÿ, à ¸ , à ¸¡, à ¸¢, à ¸£, à ¸¤, à ¸¥, à ¸¦, à ¸§, à ¸¨, à ¸©, à ¸ª, à ¸«, à ¸¬, à ¸Â, à ¸®, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
I/CalendarProvider2(  690): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver(  690): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
I/ActivityManager(  406): Resuming delayed broadcast
I/ActivityManager(  406): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=734 uid=10009 gids={50009, 3003, 1028, 1015}
D/CountryDetector(  406): The first listener is added
V/MmsConfig(  734): mnc/mcc:
V/MmsConfig(  734): tag: bool value: enabledMMS - true
V/MmsConfig(  734): tag: int value: maxMessageSize - 307200
V/MmsConfig(  734): tag: int value: maxImageHeight - 480
V/MmsConfig(  734): tag: int value: maxImageWidth - 640
V/MmsConfig(  734): tag: int value: defaultSMSMessagesPerThread - 10000
V/MmsConfig(  734): tag: int value: defaultMMSMessagesPerThread - 1000
V/MmsConfig(  734): tag: int value: minMessageCountPerThread - 10
V/MmsConfig(  734): tag: int value: maxMessageCountPerThread - 5000
V/MmsConfig(  734): tag: string value: uaProfUrl - http://www.google.com/oha/rdf/ua-profile-kila.xml
V/MmsConfig(  734): tag: int value: recipientLimit - -1
V/MmsConfig(  734): tag: bool value: enableMultipartSMS - true
V/MmsConfig(  734): tag: int value: smsToMmsTextThreshold - -1
V/MmsConfig(  734): tag: bool value: enableSlideDuration - true
V/MmsConfig(  734): tag: int value: maxMessageTextSize - -1
I/ActivityManager(  406): Delay finish: com.android.mms/.transaction.MmsSystemEventReceiver
I/ActivityManager(  406): Delay finish: com.android.mms/.transaction.SmsReceiver
I/ActivityManager(  406): Start proc com.android.onetimeinitializer for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver: pid=760 uid=10011 gids={50011}
D/Mms:app (  734): cancelNotification
V/OneTimeInitializerRece(  760): OneTimeInitializerReceiver.onReceive
I/ActivityManager(  406): Delay finish: com.android.onetimeinitializer/.OneTimeInitializerReceiver
I/ActivityManager(  406): Start proc com.android.calendar for broadcast com.android.calendar/.alerts.AlertReceiver: pid=774 uid=10019 gids={50019, 3003}
D/ExtensionsFactory(  774): No custom extensions.
D/AlertReceiver(  774): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
I/ActivityManager(  406): Delay finish: com.android.calendar/.alerts.AlertReceiver
D/AlertService(  774): 0 Action = android.intent.action.BOOT_COMPLETED
D/AlertService(  774): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler(  774): No events found starting within 1 week.
D/dalvikvm(  529): GC_CONCURRENT freed 250K, 10% free 3009K/3320K, paused 3ms+4ms, total 29ms
I/AudioMixer(  123): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/audio_hw_primary(  123): start_output_stream... 2010032040, device 2
W/audio_hw_primary(  123): card 0, port 0 device 0x2
W/audio_hw_primary(  123): rate 44100, channel 2 period_size 0xc0
D/PhoneStatusBar(  457): disable: < expand icons alerts ticker system_info back* home* recent* clock* search* >
W/InputMethodManagerService(  406): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2c6a6ed8 attribute=null, token = android.os.BinderProxy@2c663448
V/MediaScanner(  529): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@2c550318
V/MediaScanner(  529): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@2c550318
I/ActivityManager(  406): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=799 uid=10022 gids={50022, 1028}
V/AlarmClock(  799): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
V/AlarmClock(  799): AlarmInitReceiver - Reset timers and clear stopwatch data
I/AlarmClock(  799): Displaying next alarm time: ''
V/AlarmClock(  799): AlarmInitReceiver finished
I/ActivityManager(  406): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=814 uid=10024 gids={50024, 3003, 1028, 1015}
D/ActivityThread(  814): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
W/AudioTrack(  406): AUDIO_OUTPUT_FLAG_FAST denied by client due to mismatching sample rate (48000 vs 44100)
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c615618 VFED..CL ......ID 0,0-72,72 #0} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000001
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c6146d0 VFED..CL ......ID 99,0-171,72 #1} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000002
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c608b68 VFED..CL ......ID 198,0-270,72 #2} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000003
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c6092b0 VFED..CL ......ID 297,0-369,72 #3} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000004
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c60f428 VFED..CL ......ID 396,0-468,72 #4} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000005
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c559e50 VFED..CL ......ID 495,0-567,72 #5} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000006
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c7738c8 VFED..CL ......ID 594,0-666,72 #6} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000007
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c774218 VFED..CL ......ID 693,0-765,72 #7} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000008
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c774b68 VFED..CL ......ID 0,78-72,150 #8} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x00000009
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c7754b8 VFED..CL ......ID 99,78-171,150 #9} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000a
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c775e08 VFED..CL ......ID 198,78-270,150 #a} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000b
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c776758 VFED..CL ......ID 297,78-369,150 #b} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000c
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c7770a8 VFED..CL ......ID 396,78-468,150 #c} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000d
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c777b30 VFED..CL ......ID 495,78-567,150 #d} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000e
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c778480 VFED..CL ......ID 594,78-666,150 #e} during layout: running second layout pass
W/ResourceType(  561): No package identifier when getting name for resource number 0x0000000f
W/View    (  561): requestLayout() improperly called by com.android.launcher2.PagedViewIcon{2c778dd0 VFED..CL ......ID 693,78-765,150 #f} during layout: running second layout pass
D/dalvikvm(  561): GC_FOR_ALLOC freed 1529K, 30% free 3835K/5424K, paused 17ms, total 23ms
I/dalvikvm-heap(  561): Grow heap (frag case) to 4.578MB for 817360-byte allocation
D/dalvikvm(  561): GC_CONCURRENT freed 15K, 15% free 4618K/5424K, paused 3ms+2ms, total 19ms
D/dalvikvm(  561): WAIT_FOR_CONCURRENT_GC blocked 16ms
D/dalvikvm(  561): GC_FOR_ALLOC freed <1K, 15% free 4620K/5424K, paused 14ms, total 14ms
I/dalvikvm-heap(  561): Grow heap (frag case) to 5.556MB for 1039840-byte allocation
D/dalvikvm(  561): GC_CONCURRENT freed <1K, 13% free 5635K/6440K, paused 2ms+3ms, total 24ms
D/dalvikvm(  561): WAIT_FOR_CONCURRENT_GC blocked 20ms
I/ActivityManager(  406): Delay finish: com.android.email/.service.EmailBroadcastReceiver
D/dalvikvm(  561): GC_FOR_ALLOC freed 73K, 11% free 5754K/6440K, paused 25ms, total 29ms
I/dalvikvm-heap(  561): Grow heap (frag case) to 6.790MB for 1171384-byte allocation
D/dalvikvm(  561): GC_CONCURRENT freed 5K, 10% free 6892K/7584K, paused 6ms+3ms, total 28ms
D/dalvikvm(  561): WAIT_FOR_CONCURRENT_GC blocked 22ms
D/dalvikvm(  561): WAIT_FOR_CONCURRENT_GC blocked 18ms
D/dalvikvm(  814): GC_CONCURRENT freed 201K, 9% free 2886K/3152K, paused 6ms+6ms, total 696ms
W/ActivityManager(  406): Unable to start service Intent { cmp=com.android.email/.service.AttachmentDownloadService } U=0: not found
I/Email   (  814): Observing account changes for notifications
I/ActivityManager(  406): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings} from pid 561
D/PermissionCache(  120): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (230 us)
I/ARMAssembler(  120): generated scanline__00000077:03515104_00008001_00000000 [113 ipp] (134 ins) at [0x6d8071f0:0x6d807408] in 154959 ns
D/dalvikvm(  561): GC_CONCURRENT freed 121K, 3% free 8048K/8268K, paused 3ms+21ms, total 136ms
D/dalvikvm(  406): GC_CONCURRENT freed 354K, 8% free 5477K/5896K, paused 14ms+31ms, total 124ms
I/InputDispatcher(  406): Dropping event because there is no touchable window at (302, 327).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (257, 341).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (216, 355).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (172, 368).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (135, 378).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (105, 384).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (80, 391).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (65, 396).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (52, 399).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (50, 399).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (48, 399).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (45, 398).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (42, 395).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (36, 393).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (31, 389).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (25, 387).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (22, 384).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (20, 383).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (16, 380).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (14, 379).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (13, 378).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (12, 377).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (10, 375).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (9, 374).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (8, 373).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (7, 370).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (7, 369).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (6, 365).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (6, 363).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (3, 356).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 352).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 348).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 346).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 343).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 342).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 338).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 334).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 331).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 328).
D/dalvikvm(  649): GC_CONCURRENT freed 128K, 6% free 3007K/3192K, paused 13ms+6ms, total 61ms
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 324).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 323).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (2, 321).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (4, 319).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (4, 316).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (5, 314).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (6, 312).
I/ActivityManager(  406): Delaying start of: ServiceRecord{2c7bf1f8 u0 com.android.exchange/.service.EmailSyncAdapterService}
I/InputDispatcher(  406): Dropping event because there is no touchable window at (7, 310).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (9, 307).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (11, 305).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (12, 303).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (14, 301).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (17, 298).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (18, 296).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (19, 295).
I/ActivityManager(  406): Start proc com.android.exchange for service com.android.exchange/.service.EmailSyncAdapterService: pid=838 uid=10025 gids={50025, 3003, 1028, 1015}
I/InputDispatcher(  406): Dropping event because there is no touchable window at (21, 293).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (22, 292).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (24, 289).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (25, 288).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (26, 287).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (27, 286).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (29, 285).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (30, 284).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (31, 283).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (32, 282).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (34, 280).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (36, 278).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (38, 276).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (39, 275).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (42, 273).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (43, 272).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (45, 271).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (50, 269).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (52, 267).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (54, 266).
I/ActivityManager(  406): Displayed com.android.settings/.Settings: +871ms
I/LauncherIconVisibilityManager(  542): Boot has been completed
I/LauncherIconVisibilityManager(  542): Activity has already been disabled: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
D/AlertReceiver(  774): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertService(  774): 0 Action = android.intent.action.PROVIDER_CHANGED
W/audio_hw_primary(  123): do_out_standby... 2010032040
I/ActivityManager(  406): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from pid 649
D/SubSettings(  649): Launching fragment com.android.settings.WirelessSettings
D/WirelessSettings(  649): onCreate: mManageMobilePlanMessage=null
V/NFC     (  649): this device does not have NFC support
D/WirelessSettings(  649): initSmsApplicationSetting:
D/dalvikvm(  649): GC_CONCURRENT freed 127K, 6% free 3318K/3504K, paused 2ms+7ms, total 42ms
I/InputDispatcher(  406): Dropping event because there is no touchable window at (93, 183).
D/WirelessSettings(  649): updateSmsApplicationSetting:
I/InputDispatcher(  406): Dropping event because there is no touchable window at (93, 184).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 189).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 195).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 201).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 211).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 235).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (91, 275).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (102, 320).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (116, 374).
I/InputDispatcher(  406): Dropping event because there is no touchable window at (128, 430).
I/ActivityManager(  406): Displayed com.android.settings/.SubSettings: +476ms
D/WirelessSettings(  649): onPreferenceTreeClick: preference=Tethering & portable hotspot
D/SubSettings(  649): Launching fragment com.android.settings.TetherSettings
V/WebViewChromiumFactoryProvider(  649): Binding Chromium to main looper Looper (main, tid 1) {2c4fab58}
I/LibraryLoader(  649): Expected native library version number "",actual native library version number ""
I/chromium(  649): [INFO:library_loader_hooks.cc(116)] Chromium logging enabled: level = 0, default verbosity = 0
I/BrowserStartupController(  649): Initializing chromium process, renderers=0
D/libEGL  (  649): loaded /system/lib/egl/libGLES_android.so
E/chromium(  649): [ERROR:gl_surface_egl.cc(169)] No suitable EGL configs found.
E/chromium(  649): [ERROR:gl_surface_egl.cc(702)] GLSurfaceEGL::InitializeOneOff failed.
E/chromium(  649): [ERROR:gpu_info_collector.cc(86)] gfx::GLSurface::InitializeOneOff() failed
W/chromium(  649): [WARNING:mailbox_synchronizer.cc(36)] MailboxSync not supported due to missing EGL image/fence support
W/chromium(  649): [WARNING:proxy_service.cc(890)] PAC support disabled because there is no system implementation
I/GlobalDismissManager(  774): no sender configured
D/AlertService(  774): Beginning updateAlertNotification
D/dalvikvm(  649): GC_CONCURRENT freed 162K, 6% free 3560K/3780K, paused 3ms+3ms, total 57ms
I/ActivityManager(  406): Displayed com.android.settings/.SubSettings: +579ms
D/AlertService(  774): No fired or scheduled alerts
V/SmsReceiverService(  734): onStart: #1 mResultCode: -1 = Activity.RESULT_OK
I/ActivityManager(  406): Delay finish: com.android.providers.calendar/.CalendarProviderBroadcastReceiver
I/ActivityManager(  406): Waited long enough for: ServiceRecord{2c7ac728 u0 com.android.music/.MediaPlaybackService}
W/ResourceType(  649): getEntry failing because entryIndex 129 is beyond type entryCount 4
I/ResourceUtils(  542): Found default value: resource=phantom_sudden_move_event_device_list build=[HARDWARE=freescale MODEL=EVK_MX6SL BRAND=Freescale MANUFACTURER=Freescale] default=false
D/dalvikvm(  542): GC_CONCURRENT freed 173K, 7% free 3144K/3376K, paused 6ms+9ms, total 48ms
I/ResourceUtils(  542): Found default value: resource=keyboard_heights build=[HARDWARE=freescale MODEL=EVK_MX6SL BRAND=Freescale MANUFACTURER=Freescale] default=
W/SubtypeSwitcher(  542): Can't find Emoji subtype
W/SubtypeSwitcher(  542): No input method subtype found; return dummy subtype: android.view.inputmethod.InputMethodSubtype@d78b2ed0
D/dalvikvm(  542): GC_FOR_ALLOC freed 159K, 7% free 3243K/3460K, paused 17ms, total 22ms
D/dalvikvm(  542): GC_CONCURRENT freed 363K, 13% free 3294K/3768K, paused 3ms+9ms, total 47ms
D/dalvikvm(  542): GC_FOR_ALLOC freed 71K, 12% free 3334K/3768K, paused 21ms, total 21ms
I/dalvikvm-heap(  542): Grow heap (frag case) to 3.625MB for 331792-byte allocation
D/dalvikvm(  542): GC_FOR_ALLOC freed 56K, 13% free 3602K/4096K, paused 24ms, total 24ms
D/dalvikvm(  542): GC_FOR_ALLOC freed 449K, 18% free 3379K/4096K, paused 32ms, total 32ms
D/dalvikvm(  542): GC_CONCURRENT freed 87K, 8% free 3803K/4096K, paused 4ms+9ms, total 70ms
D/dalvikvm(  542): WAIT_FOR_CONCURRENT_GC blocked 10ms
D/dalvikvm(  542): GC_CONCURRENT freed 698K, 18% free 3606K/4364K, paused 6ms+19ms, total 114ms
I/ActivityManager(  406): Waited long enough for: ServiceRecord{2c75bbc8 u0 com.android.calendar/.alerts.InitAlarmsService}
D/dalvikvm(  542): GC_FOR_ALLOC freed 117K, 18% free 3586K/4364K, paused 62ms, total 63ms
I/dalvikvm-heap(  542): Grow heap (frag case) to 3.969MB for 434192-byte allocation
D/dalvikvm(  542): GC_CONCURRENT freed 61K, 18% free 3948K/4792K, paused 4ms+4ms, total 41ms
D/dalvikvm(  542): WAIT_FOR_CONCURRENT_GC blocked 32ms
D/dalvikvm(  542): GC_CONCURRENT freed 691K, 22% free 3768K/4792K, paused 3ms+3ms, total 40ms
D/dalvikvm(  542): WAIT_FOR_CONCURRENT_GC blocked 13ms
W/ViewPager(  542): Requested offscreen page limit 0 too small; defaulting to 1
I/LatinIME:LogUtils(  542): Dictionary info: dictionary = contacts.en_US.dict ; version = ? ; date = ?
D/dalvikvm(  542): GC_CONCURRENT freed 316K, 19% free 3913K/4792K, paused 5ms+29ms, total 174ms
D/dalvikvm(  542): GC_FOR_ALLOC freed 130K, 21% free 3789K/4792K, paused 117ms, total 118ms
I/dalvikvm-heap(  542): Grow heap (frag case) to 4.375MB for 652816-byte allocation
D/dalvikvm(  542): GC_CONCURRENT freed <1K, 19% free 4426K/5432K, paused 7ms+2ms, total 29ms
D/dalvikvm(  542): WAIT_FOR_CONCURRENT_GC blocked 20ms
D/dalvikvm(  542): GC_FOR_ALLOC freed 0K, 19% free 4426K/5432K, paused 21ms, total 21ms
I/dalvikvm-heap(  542): Grow heap (frag case) to 4.999MB for 652816-byte allocation
D/dalvikvm(  542): GC_CONCURRENT freed 0K, 17% free 5064K/6072K, paused 3ms+2ms, total 25ms
W/InputMethodManagerService(  406): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2c7ac240 attribute=null, token = android.os.BinderProxy@2c75c4a0
D/dalvikvm(  649): GC_CONCURRENT freed 177K, 6% free 3785K/4020K, paused 8ms+3ms, total 178ms
D/WifiStateMachine(  406): handleMessage: E msg.what=131093
E/WifiHW  (  406): Loading WiFi driver here
E/WifiHW  (  406): *****onebox_nongpl.ko inserted
E/WifiHW  (  406): *****wlan.ko inserted
E/WifiHW  (  406): ****wlan_wep.ko inserted
E/WifiHW  (  406): *****wlan_tkip.ko inserted
E/WifiHW  (  406): *****wlan_ccmp.ko inserted
E/WifiHW  (  406): ********wlan_acl.ko inserted
E/WifiHW  (  406): *****wlan_xauth.ko inserted
E/WifiHW  (  406): ***wlan_scan_sta.ko inserted
D/Tethering(  406): interfaceAdded rpine0
D/Tethering(  406): rpine0 is not a tetherable iface, ignoring
D/Tethering(  406): interfaceLinkStateChanged rpine0, false
D/Tethering(  406): interfaceStatusChanged rpine0, false
E/WifiHW  (  406): ***********onebox_gpl.ko
E/WifiHW  (  406): ********* ALL ko inserted successfully
D/WifiStateMachine(  406): setWifiApState: enabling
D/WifiStateMachine(  406): transitionTo: destState=SoftApStartingState
D/WifiStateMachine(  406): handleMessage: new destination call exit/enter
D/WifiStateMachine(  406): setupTempStateStackWithStatesToEnter: X mTempStateStackCount=1,curStateInfo: state=DefaultState,active=true,parent=null
D/WifiStateMachine(  406): invokeExitMethods: InitialState
D/WifiStateMachine(  406): moveTempStackToStateStack: X mStateStackTop=1,startingIndex=1,Top=SoftApStartingState
D/WifiStateMachine(  406): invokeEnterMethods: SoftApStartingState
D/WifiStateMachine(  406): handleMessage: E msg.what=131100
D/WifiStateMachine(  406): processMsg: SoftApStartingState
D/Tethering(  406): interfaceAdded wlan0
D/WifiStateMachine(  406): handleMessage: E msg.what=131101
D/WifiStateMachine(  406): deferMessage: msg=131101
D/Tethering(  406): sendTetherStateChangedBroadcast 1, 0, 0
D/Tethering(  406): interfaceLinkStateChanged wlan0, false
D/Tethering(  406): interfaceStatusChanged wlan0, false
D/Tethering(  406): interfaceStatusChanged redpine1 wlan0
D/Tethering(  406): interfaceStatusChanged redpine2wlan0
D/Tethering(  406): InitialState.processMessage what=4
D/Tethering(  406): sendTetherStateChangedBroadcast 0, 0, 0
E/WifiHW  (  118): RAVI:****Vap Creation Output:
E/WifiHW  (  118):
E/WifiHW  (  118): RAVI:****Inside AP wifi.c wifi_get_fw_path out_iface is wlan0
E/SoftapController(  118): RAVI:VAP type changed to AP
E/NetdConnector(  406): NDC Command {10 softap fwreload wlan0 AP} took too long (1497ms)
E/NetdConnector(  406): NDC Command {11 bandwidth gettetherstats} took too long (1116ms)
E/SoftapController(  922): RAVI: chwon Error is 0
E/SoftapController(  922): RAVI:chmod Error is 0
E/SoftapController(  922): RAVI: hard code chwon Error is 0
E/SoftapController(  922): RAVI:hard code Error is 0
E/SoftapController(  922): RAVI:***Executing hostapd*****
E/SoftapController(  118): RAVI:***Inside else of Executing hostapd executing iwconfig wlan0 freq6*****
D/SoftapController(  118): SoftAP started successfully
D/WifiStateMachine(  406): Soft AP start successful
E/NetdConnector(  406): NDC Command {13 softap startap} took too long (2225ms)
D/WifiStateMachine(  406): handleMessage: E msg.what=131094
D/WifiStateMachine(  406): setWifiApState: enabled
D/WifiStateMachine(  406): transitionTo: destState=SoftApStartedState
D/WifiStateMachine(  406): invokeExitMethods: SoftApStartingState
D/WifiStateMachine(  406): moveTempStackToStateStack: X mStateStackTop=1,startingIndex=1,Top=SoftApStartedState
D/WifiStateMachine(  406): invokeEnterMethods: SoftApStartedState
D/WifiStateMachine(  406): moveDeferredMessageAtFrontOfQueue; what=131101
D/WifiStateMachine(  406): processMsg: SoftApStartedState
E/NetdConnector(  406): NDC Command {14 bandwidth gettetherstats} took too long (2231ms)
D/CommandListener(  118): Trying to bring up wlan0
D/WifiStateMachine(  406): addressUpdated: 192.168.43.1/24 on wlan0 flags 128 scope 0
D/Tethering(  406): interfaceLinkStateChanged rpine0, true
D/Tethering(  406): interfaceStatusChanged rpine0, true
D/Tethering(  406): interfaceLinkStateChanged wlan0, true
D/Tethering(  406): interfaceStatusChanged wlan0, true
D/Tethering(  406): thether interface redpine3wlan0
D/Tethering(  406): Tethering wlan0
D/Tethering(  406): Tethering Mutyalarao wlan0
E/Tethering(  406): Tried to Tether an unknown iface :wlan0, ignoring
E/WifiStateMachine(  406): Error tethering on wlan0
D/WifiStateMachine(  406): handleMessage: E msg.what=131212
D/WifiStateMachine(  406): Link configuration changed for netId: -1 old: {LinkAddresses: []  Routes: [] DnsAddresses: [] Domains: nullMTU: 0}new: {InterfaceName: wlan0 LinkAddresses: [192.168.43.1/24,]  Routes: [] DnsAddresses: [] Domains: nullMTU: 0}
D/InitAlarmsService(  774): Clearing and rescheduling alarms.
D/ConnectivityService(  406): Sampling interval elapsed, updating statistics ..
D/ConnectivityService(  406): Done.
D/ConnectivityService(  406): Setting timer for 720seconds
D/dalvikvm(  406): GC_CONCURRENT freed 542K, 10% free 5583K/6192K, paused 13ms+5ms, total 89ms
I/MediaFocusControl(  406):  AudioFocus  abandonAudioFocus() from android.media.AudioManager@2c504948com.android.music.MediaPlaybackService$3@2c5037c8
I/ActivityManager(  406): Start proc com.android.musicfx for broadcast com.android.musicfx/.ControlPanelReceiver: pid=930 uid=10010 gids={50010, 3003, 3002}
V/MusicFXControlPanelReceiver(  930): onReceive
V/MusicFXControlPanelReceiver(  930): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
V/MusicFXControlPanelReceiver(  930): Package name: com.android.music
V/MusicFXControlPanelReceiver(  930): Audio session: 7
V/MusicFXControlPanelEffect(  930): closeSession(android.app.ReceiverRestrictedContext@2c4ffc48, com.android.music, 7)
^[[B^H
