dts: configure SPI
dts: configure SPI
BrilliantovKiri
Senior Contributor I
Hello!
I work with custom iMX287 CPU board.
On board device connected to SSP2_MOSI, SSP2_SCK and SSP2_CS1, follow my code in dts-file:
apb@80000000 {
    apbh@80000000 {
        ssp0: ssp@80010000 {
                compatible = "fsl,imx28-mmc";
                pinctrl-names = "default";
                pinctrl-0 = <&mmc0_4bit_pins_a
                        &mmc0_cd_cfg
                        &mmc0_sck_cfg
                bus-width = <4>;
                status = "okay";
        ssp2: ssp@80014000 {
                #address-cells = <1>;
                #size-cells = <0>;
                compatible = "fsl,imx28-spi";
                pinctrl-0 = <&spi2_pins>;
                status = "okay";
                spi2_pins: spi2@0 {
                    reg = <0>;
                    fsl,pinmux-ids = <
                        MX28_PAD_SSP2_SCK__SSP2_SCK
                        MX28_PAD_SSP2_MOSI__SSP2_CMD
                        /* SSP2_CS1 */
                        MX28_PAD_SSP2_SS1__SSP2_D4
                    fsl,drive-strength = <MXS_DRIVE_8mA>;
                    fsl,voltage = <MXS_VOLTAGE_HIGH>;
                    fsl,pull-up = <MXS_PULL_ENABLE>;
Unforunately spidev not present, linux log contained this - spi_master spi1: cannot find modalias for /apb@80000000/apbh@80000000/ssp@80014000/spi2@0
I not understand this message, why spi1 can't found modalis if I not use spi1?
Can you help me?
Thank you and excuse my bad english.
Labels (2)
Tags (3)
BrilliantovKiri
apbh@80000000 {
                #size-cells = <0>;
                status = "okay";
                dm631@0 {
                    reg = <0>;
                    compatible = "spidev";
                    spi-max-frequency = <10000000>;
    pinctrl@80018000 {
        spi2_pins: spi2_pins@0 {
                    reg = <0>;
                    fsl,pinmux-ids = <
                        /* SSP2_CS1 */
BrilliantovKiri
Ok, I move SSP2 pins description to pinctrl@80018000 sections and this solve problem.
Unfortunately /dev/spidev is not present.
lategoodbye
Hi Kirill,
did you specify spidev as a SPI slave of ssp2 in devicetree?
BrilliantovKiri
Hello, Stefan!
Can you share example or link on example?
csotoalonso
Just to make sure... Do you have spidev support in your kernel? If you have it as a module, you should load the module. Try modprobe spidev and see what happens.
BrilliantovKiri
Hello, Carlos!
I embedded SPI support to linux:
$ grep SPI .config | grep -v \#
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_MXS=y
CONFIG_SPI_SPIDEV=y
