SD card database?
SD card database?
mattgeerts
I am using FRDM-KE06Z with Adafruit Data Logger shield. My hardware is working completely fine. I'm currently data logging to csv files to be opened with excel.
I would like to write instead to a database file that I can use to generate cross-referencing reports using some database software. MS Access would be fine, though I'm sure there are better options.
I have searched extensively but I can't seem to find a single example or discussion about writing to a database file (memory, SD card, network, whatever) via embedded systems of any sort (except running Linux).
Thanks!
