Where should iomux setting be applied in kernel tree
Question asked by Mihaita Ivascu on Jul 22, 2015
Latest reply on Aug 7, 2015 by Mihaita Ivascu
     I'm working on enabling CCM_CLKO2 clock on GPIO3 as described in iMX6 quad manual. I was told I need to enable GPIO3 in bootloader, I assume is in devicetree (.dtsi) files.
Also, I don't know where should I set the CCM_CCOSR register. In the drivers/pinctrl/pinctrl-imx6q.c file ? I see there are defined the padding.
    Where is the correct place to set this iomux configuration ?
IOMUXC_SW_MUX_CTL_PAD_GPIO03
IOMUXC_SW_PAD_CTL_PAD_GPIO03
Thank you,
        Mihaita
