CST HAB4 i.MX6 Public Key Store index=5
benjaminh3
HI,
the HAB Code-Signing Tool User’s Guide Rev. 2.2 10/2014 states that slots of the i.MX6 public key store range from 0 to 5 with 1=SRK and 2=CSF, hence 2 to 5 are for signing keys.
5.2.6 Install Key
Target Index    2, ..., 5 (HAB4)
Using the Code Signing Tool I cannot use the slot no. 5. CST fails will error
Invalid argument TargetIndex exceed max allowed in command InstallKey
while others are working.
CSF:
[Header]
Version = 4.0
Security Configuration = Open
Hash Algorithm = sha256
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
[Install SRK]
File = "./Keys/keys/SRK_1_2_3_4_table.bin"
Source index = 0
[Install CSFK]
File = "./Keys/crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
Verification index = 0
Target index = 5
File = "./Keys/crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem"
[Authenticate Data]
Verification index = 5
fixed Version entry in csf: neither with 4.1 nor 4.0 it is working.
utkarsh_gupta
The issue is found to be in the documentation. Key store index = 5 is not supported. Key store index range from 0 ... 4.
We will be making this change in the documentation and post it on the web with next release of CST.
Utkarsh
utkarsh_gupta
Utkarsh
utkarsh_gupta
A CST software bug has been reported and this issue is being worked on. Thank you for bringing this to our notice.
Utkarsh
Yuri
   Please try the recent CST tool 2.3.
http://www.freescale.com/webapp/Download?colCode=IMX_CST_TOOL&appType=license&location=null&Parent_n...
Yuri
benjaminh3
Now using cst from cst-2.3.1.tar.gz instead of cst-2.2 using csf above:
Code Signing Tool release version BLN_CST_MAIN_02.03.00
