I am using MC56F8037 DSC Microcontroller for generating PWM . I was able to use the PWM component for generating PWM waveform after setting time period and initial pulse width
and I was able to change its Duty Cycle Using SetRatio16 Function. But on using more than one PWM component, Iam not able to change Duty Cycle and PWM Waveform generated is of
time period and initial pulse width set on initialisation. I require a minimum of 4 different PWM signals whose duty cycle varies dynamically.
Solved! Go to Solution.
To get 4 different PWM signals, user just needs to add one PWMMC component, please see the below screenshot. The four PWM channels can be set with different duty cycle, but they must have the same period, because MC56F8037 only have one PWM module and one counter in it. The period is determined by CMOD register.
