How to Set hexadecimal data display format in the Terminal window  of the Hiwave?
xiaochenqiang
Hi:
  I am working on the Virtual SCI,I have received date in the Terminal window,but I want the data display in hexadecimal format ,How to set it?Thank you!
Martin35804
you will have to make a conversion function from whatever format your get to hex.
or by using a printf function:
int a = 3;
printf
("0x%x\n", a);
this will give you 0x3
iggi
The data (characters) you sent to PC terminal should be displayed as they were sent.
So, it depends on what you actually send to terminal.
In this case, a simple putc() would work.
//=============================int k;
for (k = 0; k<100; k++) {
     putc(k);
btw, what MCU do you use?
xiaochenqiang
why no one reply to the question?
