uart using CTS and RTS
davidmartínezag
hello, i have a trouble using CTS and RTS. I used the normal configuration with interrupt from the KMSWDRVAPIRM_SW's drivers and go well, but when I try it using the other way, I am not sure if it go well. My microcontroller belong to MKMxxZxxACxx5RM's family. Just making the configuration of the CTS and RTS, I did it using UARTx_MODEM.
Any idea?
Thanks for advance.
isaacavila
Hi David,
Are you still having this issue?
Isaac
davidmartínezag
sorry for not responding before, i had holidays. Finally i got to find a solution. Thanks.
isaacavila
Hello David,
Could you attach your project? Need to see your UART configuration.
Also, I would like to know it your are using TWR-KM34Z50MV3 hardware.
Isaac
