Is there some way to stop the data stored in the EEPROM memory from being erased when you program/debug the S12G128.
I am using the PE-Micro USB Multilink.
Ray.
Solved! Go to Solution.
hello
please follow attached video to avoid eeprom being erased during download.
please don't forget save configuration after setting.
with video setting, then next time you relaunch debugger, eeprom will not be erased.
Zhang Jun
hello
Zhang Jun
